RUH ROH...this can't be good! Bent rod; cracked arm!!
Old 05-17-2012, 09:10 PM
bad12jr's Avatar
bad12jr
bad12jr is offline
I've seen this on other forums a few times seems to just be a bad cast and some other perfect conditions that are causes. Lucky the push rod is normally the weak link and will bend before something more expensive.
Just out of curiosity why did you change injectors.
Old 05-17-2012, 09:22 PM
Action4478's Avatar
Action4478
Action4478 is offline
Or not ......
Old 05-17-2012, 10:06 PM
FallstonYJ's Avatar
FallstonYJ
FallstonYJ is offline
From the time I bought the truck it was hard starting and ran very rough when it first started. Then I had a meltdown towing my jeep when I lost power and started smoking like a locomotive. Spent a couple of weeks researching possible causes and finally had a local diesel specialist take a look. He came away thinking it might just be injector o-rings and recommended I start with that. I ordered the o-rings but then started thinking about how much work that was going to be and did I really want to go through all that and put injectors with 240K on them back in. The conclusion I came to was no. So........after much searching I ordered 150's from Swamps and a TS chip. Hopefully I can get this all back together and will be able to realize the benefits of the new injectors without any more issues with the rods. Sorry to be so long winded!
Old 05-17-2012, 10:08 PM
FallstonYJ's Avatar
FallstonYJ
Originally Posted by Action4478
Or not ......
Action4478, you suspect it may be something more?? I hope not..........I am way too far into this thing already!
Old 05-18-2012, 05:22 AM
bad12jr's Avatar
bad12jr
bad12jr is offline
They all seem to break in the same spots. Weak points in the cast and just the right amount of heat. There are quite a few competition trucks running up in the 4000 4500 rpm range with no problems. The injector nozzle spring breaking could have been the perfect condition that exagerated the weak point in the rocker.
82fordowner
03-21-2015 10:27 AM
cookingguy
11-26-2014 02:04 PM
rLmcowboy
10-20-2012 08:27 AM
forrider
04-07-2011 07:57 AM
jcahicks
17
03-08-2011 09:51 PM
Quick Reply: RUH ROH...this can't be good! Bent rod; cracked arm!!
