Bronco fuel tank in 96 f250?
Old 05-13-2012, 09:48 AM
RKraft's Avatar
RKraft
RKraft is offline
I want to know if the 92-96 Ford Bronco tank will fit in my 1996 F250 for rear replacement. I know years ago I installed on in my 78 F250 & assuming I should be able to do the same here.
Randy
Old 05-13-2012, 12:07 PM
big vann's Avatar
big vann
big vann is offline
I installed one in my '88 F250 when I replaced the efi 302 with a carbed 460.I removed rear and side tanks to allow a true dual exhaust.Make sure to get the pick-up with the tank.If you're EFI,then you'll need one with a fuel pump.Get a Bronco tank/pick-up from the same year truck and the harness plugs right in.Another thing to consider is a plastic tank from Bronco Graveyard.It'll never rust.I made my own straps but they are available wherever you get your tank from.
1969furd
01-22-2010 01:26 PM
pwrtrip
1978 - 1996 Big Bronco
10-31-2009 11:31 AM
300 Buster
10-11-2009 10:19 PM
chrisvman
04-24-2005 03:45 PM
oldhalftons
04-12-2005 10:33 PM
Quick Reply: Bronco fuel tank in 96 f250?
