Radiator cleaning
Old 05-03-2003, 06:36 AM
Shannonm1's Avatar
Shannonm1
Shannonm1 is offline
Radiator cleaning
Is there any way of adding anything to clean a radiator? I have a 1984 f150 and the radiator doesn't flow well. I t has buildup on the ends of the tubes restricting flow. Is ther anyway of cleaning this without having to pull the radiator?
Old 05-03-2003, 09:00 PM
steve83's Avatar
steve83
steve83 is offline
Radiator cleaning
Look for "Bar's" products. Anything that eats away deposits will eat away some of the metal, too, so don't expect it to last much longer anyway. You should use rainwater or distilled water to fill your radiator, and keep antifreeze in it - it prevents the inside of the block from rusting & clogging the tanks. Many shops have adapters to backflush a radiator with air pressure, which is the best way to remove the sediment. If it's gone, get a lifetime radiator from almost any parts store.
roadrash63
23
12-16-2016 12:07 PM
comsupany
05-03-2016 07:30 AM
petepetersen
11-11-2015 10:02 AM
735.0Short
40
10-23-2005 12:09 PM
whatdyisit
11-21-2004 08:47 AM
Quick Reply: Radiator cleaning
