Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
'04 Explorer Won't Start
Old 05-04-2012, 12:29 AM
farmerwill's Avatar
farmerwill
farmerwill is offline
Question '04 Explorer Won't Start
My father in law has an '04 Explorer with the 4.0. He tells me he was coming home from an errand and it stopped dead, like the fuel shut off. I checked the inertia switch and it was ok. He replaced the fuel pump but that didnt fix it either. His description is as follows: when he turns the key, it will start, run about 2 seconds, if that, and shut off. It will not restart, if you want to call it that, unless it sits for a 1/2 hour or so. Then it's the same thing all over again.
Any help would be appreciated.
Old 05-04-2012, 12:55 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
No guessing, will it start and run on external test fuel???
Connect a fuel gauge and run a complete fuel pressure test.
Check the relays, FP CPU..... Philip
Old 05-06-2012, 12:50 PM
farmerwill's Avatar
farmerwill
It will not fire on ether...i have spark.
Old 05-06-2012, 05:24 PM
aquanaut20's Avatar
aquanaut20
Pull the Fuel relay, inject quick start into manifold via vacuum nipple and start....
If you are able to start this way, you have a fuel issue. The only way to diagnose that issue is with a fuel pressure gauge and completing all 5 tests.
..... Philip
shovel_1972
1978 - 1996 Big Bronco
04-06-2015 08:02 PM
SirArgus
02-09-2012 07:52 PM
jkarne
06-15-2010 06:50 AM
Race4Fun
25
09-29-2009 05:57 AM
jesterdog
01-30-2009 11:30 AM
Quick Reply: '04 Explorer Won't Start
