What did you do for your truck today?
What did you do for your truck today? This is an idea borrowed from another forum. It's good for posting
smaller projects with pictures you may have done that you don't want to make a new thread for.
Thomas, I would have, if I had bought that inexpensive press that I should have bought a while back. The rotors are power slots (& don't even have 10K on them) that came with the inner races already pressed in them. The play was barely even noticeable, But I had tightened it a bit a while back when I first thought I felt something. This set I used a torque wrench & the book settings/procedure.... There's still a bit of wobble.
I think its something either in the caliper or that side of the suspension. Reasons are:
1) When I went to pull the caliper off, it felt like the bolts weren't that tight for what I expect a caliper bolt should need to be loosened. When I went to tighten it back down, I didn't get a feeling of "full seating" of the bolt like you should get when you reach the end of the threads. (on both bolts) In fact it was the feeling you get tightening down a cross thread, but I also got the "feeling" like I was about to snap them off as well if I cranked even more. (They're pretty long & skinny bolts)
2) The other thing is the "clunk" I occasionally get when making a extreme/sharp turn into a high/low angle driveway or parking lot. The radius arm bushings "look" OK, but I can't put enough "stink" (checking for movement) on to the various suspension parts that frequently are the cause of wobble when loaded by braking.
RDON
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-08-2006 07:20 PM
