Oklahoma Chapter Join Chapter, Leader:
Not Too Windy To Paint......lol.....
Old 05-01-2012, 12:43 PM
cigarxtc's Avatar
cigarxtc
cigarxtc is offline
Thumbs up Not Too Windy To Paint......lol.....
Okay, i couldnt wait any longer and had to practice laying some Summit Racing paint. I set up my pop up canopy and tied some blanket walls to it and primed and painted my tailgate. This is my first attempt at automotive painting. Putting the primer down was easy enough. Man, the imperfections in the sanding really show through after primer is applied. It's not perfect but not bad for a first attempt. It's not a show truck, just my daily driver. I figure I'll paint the truck in sections to get more practice as i go along. I only painted the outside and sides.The back of the tailgate will be Herculined this week.
The weather forecast this week looks great for some auto work. Hope everyone else is able to get out and work on their projects too.
Old 05-03-2012, 06:00 PM
jwtimme's Avatar
jwtimme
jwtimme is offline
looks good, after roughing in the major body work it may take a couple coats of primer/surfacer and a block sanding to get the inferfections out. Are you using a single stage or base/clear paint system.
Old 05-03-2012, 10:21 PM
cigarxtc's Avatar
cigarxtc
cigarxtc is offline
I'm using single stage paint. Yer right, i'll have to do some sanding after spraying the primer for the smoothest finish. Next up is all the hail dings in the hood. And the cowl area looks like galvanized metal. I'm hoping the primer will stick to that ok.
Old 05-05-2012, 01:19 PM
jwtimme's Avatar
jwtimme
jwtimme is offline
defiantly need to block sand the primer before laying down paint. I will block with 100-150 grit first then shoot anther coat of primer, a coat may consist of 3-5 wet coats, then block with 220, then 320 then a final wet sanding with 400. you can use a spray can of black paint, spray the panel just lightly enough to give give it a dusting, it will help you see the low areas and get the panel strait.
Fat Ford Boy
2015 - 2020 F150
08-27-2017 01:44 PM
cigarxtc
Paint & Bodywork
06-01-2011 05:50 PM
98fordstx
1997 - 2003 F150
01-04-2008 08:10 PM
jor
Paint & Bodywork
05-05-2004 05:56 PM
Quick Reply: Not Too Windy To Paint......lol.....
