Break line blowout between fuel tank and frame
Old 04-30-2012, 11:34 PM
portsample's Avatar
portsample
portsample is offline
Driving to work this morning I noticed that the brake pedal felt slightly spongy. Then while going to meet a forklift to have a 1400# Powermatic planer loaded in the bed, my brake light came on.
The rig is in town right now, parked with a massive Powermatic planer in the back. Dang, I hope it does not rain.
The leak appears to be coming from the brake line between the frame and the fuel tank. I was not able to get a light in to see exactly what the leak is. Does anyone have any experience with leaks at this location?
Old 05-01-2012, 12:15 AM
woodnthings's Avatar
woodnthings
woodnthings is offline
The brake line back there does go from a rigid line to a flex line at the axle. It that where you are leaking? It is behind the fuel tank though!
Hmmmmm 1400# planer, I could find a use for that in my shop!
Old 05-01-2012, 12:24 AM
portsample's Avatar
portsample
Negative- the leak is between the tank and frame. Someone mentioned that this is a common place for a leak but didn't elaborate why. I was hoping someone might know...is it just a straight shot of SS tubing at that location?
Yeah- the planer is a cherry (and a real beast). A Powermatic 180.
Old 05-01-2012, 06:08 AM
Superduty ROCKS's Avatar
Superduty ROCKS
Superduty ROCKS is offline
Brake line rusted through.
Old 05-01-2012, 06:51 AM
indyF-350psd's Avatar
indyF-350psd
indyF-350psd is offline
you can't fix stupid!
yep the line is rusted through.....common area on these super duty's....
Old 05-01-2012, 10:06 AM
dirty1's Avatar
dirty1
dirty1 is offline
Happened towith approaching a stop sign with a ton of pellets in the bed. I was told it is really common as a lot of dirt, sand and salt get up in there over time and rust the line.
Old 05-01-2012, 10:07 AM
dirty1's Avatar
dirty1
dirty1 is offline
Stupid phone, it happened to me. LOL!
Old 05-02-2012, 09:31 PM
autoxtech's Avatar
autoxtech
autoxtech is offline
yep it happenned to me after a panic stop. the line busted right at the fuel tank from rusting. i replaced the entire line from the front to the rear with 3 pieces and bent them to match factory, it has been about a year and no other problems since. there are many threads about this topic.
Old 05-02-2012, 09:56 PM
critterf1's Avatar
critterf1
critterf1 is offline
Common on most pick-ups.
Old 05-03-2012, 01:25 AM
portsample's Avatar
portsample
Yeah, I had a shop do it for me. It was at a clip where mud/junk/crap got impacted and held moisture...
Old 05-05-2012, 09:50 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Yup, that is more common than air when you live where it snows.
HUGE safety problem that I wish the government would step in and MAKE every vehicle manufacturer use stainless from the factory for brake and fuel lines.
Old 05-05-2012, 11:44 AM
Rose Clifford's Avatar
Rose Clifford
Rose Clifford is offline
It probably happened here, near the cross member and the clips that hold the brake and fuel lines.
MS86
1999 to 2016 Super Duty
03-28-2017 05:12 AM
redbug
08-21-2014 07:48 PM
dobber97
07-09-2009 04:34 AM
Fordsflylow
1983 - 2012 Ranger & B-Series
05-09-2005 03:55 PM
Quick Reply: Break line blowout between fuel tank and frame
