2008 6.4L Found 3 Oil Leaks Today
i just noticed a wet spot under my 2008 today. I crawled under to see more wet spots on engine parts/steering parts. It seems to be a clear oily substance, and looks like it is coming from the lower radiator hose. I looked at the coolant reservoir and looks to be the same as the wet spots. Does this sound about right to anyone?
Wow. Three new seals less than a month before warranty expires. I wouldn't care about how three went out simultaneously, I'd just be greatful.
Mine is ok.
They don't replace the bedplate itself, just re-seal above and below it. The only way to get to it is to pull the engine (which means pulling the cab) and removing the oil pan and bed plate itself.
The mechanic that did mine was very confident that it would not leak again with the black RTV that was used. It was only a heavy seep, but there was a visible oil trail down to the bottom of the bell housing.
Get it checked out and repaired if you still have a warranty left!
Mine is doing the same thing. I tow and been driving like that for a year. Its the bed plate likely. Mine is not losing enough oil to even drip on my driveway. No way will i have them cab off and engine out again to fix it unless it gets worse. I once had the front cover leaking oil, they replaced that, that was leaking a nice amount though, left drops everywhere on my driveway.
