Psst-psst engine noise
04-28-2012, 10:28 PM
on
I have a 2005 F150, 5.4 triton. I bought the truck used and it came with an Edge tuner. It's lifted with 35's.
Under mild acceleration I get a psst-psst-psst-psst-psst-psst type noise. Sounds almost like air... It only happens in drive when you get on the gas and put a load on the engine but not always. It doesn't seem to happen if you mash the pedal...
I can't seem to replicate this sound in the driveway.
I've never heard this sound before. Any ideas?
04-29-2012, 09:31 AM
on
I've been searching the net and this site... the only thing I can find that sounds close is turbo flutter.
I don't have a turbo.
Any help please?
Thanks!
04-29-2012, 06:39 PM
on
04-29-2012, 07:29 PM
Its hard to tell from your description, maybe an exhaust manifold leak.
04-29-2012, 07:35 PM
on
I know the description is weak. It's similar to the cut off sound from an air pump. But they are short bursts...
Maybe an exhaust leak?
04-29-2012, 07:49 PM
Are all of your spark plus in place? Some of these motors had p problems where they would spit out the plugs. You may have one out of place.
04-29-2012, 08:28 PM
on
yikes. I hope it's not a plug issue.
04-29-2012, 08:34 PM
Maybe a vacuum leak somewhere
04-29-2012, 08:51 PM
on
I'll hit it with carb cleaner and see if I get a surge. The truck runs great, no noticeable power loss at all. Just the noise.
This is gonna have to be a tomorrow project.
Thanks!
Most likely an exhaust leak.
04-29-2012, 09:08 PM
Try to figure out which side, it may be a manifold to exhaust pipe gasket. Se if you can tighten it up, or stop off at an exhaust shop for $20 bucks.
04-30-2012, 11:21 AM
on
Does it have an aftermarket air intake system? Mine with a k and n does it
04-30-2012, 09:52 PM
on
05-02-2012, 07:18 PM
on
Quote:
Originally Posted by
brandonorban
interesting. Mine is stock however. I finally broke down and took it in. They couldn't find anything and told to not worry about it....
guess I'll put some louder exhaust on and ignore it.
I did have the shop change the plugs. Everything I've read about them had me uneasy. And, I hade water in the front diff.
As of today; all new fluids, new plugs, and no error codes.
09-19-2012, 08:54 AM
on
mine does this as well, only when hot. i'm pretty sure its an exhaust leak. im going to get it in, if they find anything i'll update
