Speedo gear needed
Old 04-26-2012, 08:29 AM
scf100's Avatar
scf100
scf100 is offline
Speedo gear needed
anyone know where I can get the speedo gear that goes on end of cable?
my 1961 Econoline 3 speed manual is reading about 5 mph too fast because of aftermarket wheels ( checked with a cool i-phone app!)
anyone got an idea how many teeth to change 1, 2 or?
Old 04-26-2012, 05:44 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
United Speedometer Service
2431 University St, Suite B
Riverside, CA 92507
951-742-7117
Old 04-29-2012, 05:30 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
anyone know where I can get the speedo driven gear that goes on end of cable?
Your Econoline has a nylon DRIVEN gear. 16 thru 21 teeth are available.
The same nylon DRIVEN gears are used from 1960 into the 1990's in myriad Passenger Cars/Trucks/Bronco's & Econolines. All are available from Ford for less than 5 bucks each.
Reading 5 MPH too fast: Count the number of teeth your gear has, then deduct a tooth. If you list the tooth count of your present gear, I'll give you the Ford part number/price for the one you need.
Old 04-29-2012, 06:08 AM
scf100's Avatar
scf100
scf100 is offline
gear
will do.....thanks Bill
Old 04-29-2012, 08:22 AM
scf100's Avatar
scf100
scf100 is offline
Bill,
18 tooth yellow gear is in there now....
thanks Stuart
Old 04-29-2012, 10:07 AM
NumberDummy
18 tooth yellow gear (CODZ-17271-B / teeth run this-away \\\\ ) is in there now.
C3DZ-17271-C .. 17T DRIVEN Nylon Speedometer Gear (green or white) / Teeth run this-away \\\\ / Available from Ford.
MSRP: $4.83 // FTE sponsor tousleyfordparts.com price: $3.19 / At least 3 dealers in GA have it in stock (Dallas, Cleveland, Gainsville).
Old 04-29-2012, 11:00 AM
scf100's Avatar
scf100
scf100 is offline
thanks Bill!
KsHighboy
19
03-29-2016 05:46 PM
uh60
01-20-2014 08:00 PM
460
02-19-2008 03:34 PM
MikeGV
09-26-2005 09:30 PM
bigreave
04-10-2004 09:09 AM
Quick Reply: Speedo gear needed
