Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 04-26-2012, 05:46 AM
F250GH F250GH is offline
F250GH is starting off with a positive reputation.
2008 6.4 Diesel Transmission Flush
The recommended transmission flush service that the dealer offers is $349. That 18 quarts of Motorcraft Mercon ATF, filter, and labor. (They're charging you $175 for the filter, that you can get online for $74) The oil is $7.49 a quart.
So my question is this. I have heard that some trucks experience major transmission problems resulting from the power flush. Is it really necessary to blast all of the fluid through the system? Why not just drain what comes out from dropping the pan?
The power flush blows everything through the coolers, both back and fourth, causing who knows what to the system.
Old 04-26-2012, 05:53 AM
R-T0r21on R-T0r21on is offline
R-T0r21on is starting off with a positive reputation.
Some folks say you do. The regular transmission service is drain, filter change & refill. Mine has never been flushed in 109K miles. BTW- The tranny fluid is Mercon SP or LV, not the old Mercon. Yes that stuff is pricey.
__________________
Job #1 F-350 SRW, 6.4 PSD, Auto, 4x4, supercab, long bed, Line-X, Vent visors, AFE cold air intake, MBRP "cool duals" exhaust, Bed locker electric retractable tonneau cover, Kenwood DNX-9980HD Nav. stereo w/ backup camera, Titan 60 gal. tank, Readylift leveling kit, 5" rear spring blocks, Banks intercooler, Spartan 275 hp DOC/DPF delete tune.
Old 04-26-2012, 07:10 AM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
You might find another dealer who will be more in line with prices. I am getting my transmission flushed and job #1 canister filter changed next Monday. Flush $179.95 canister filter $69.95 These filters used to sell for over $100 and for some reason they came down in price.
Old 04-26-2012, 12:53 PM
Someone mentioned a "special tool" to remove the external filter. What exactly does this "tool" look like?
Old 04-28-2012, 11:25 AM
Ronin 5729's Avatar
Ronin 5729 Ronin 5729 is offline
Ronin 5729 is gaining momentum as a positive member of FTE.
My dealer quoted $225 for the service today...
I asked if that was a hot flush to get the converter done too.
That was just for dropping the pan, changing the "filter" and adding 8 quarts.
The hot flush was "gonna be about $500".
No thanks, my local/independent transmission shop (with a ton of 6.4/5R110 experience) will do the hot flush for $250+.
I'll be doing my shortly and adding a Mag Hy-tec high capacity pan and DieselSite remote bypass filter when I'm at it and should be able to do all that for under $700.
At power levels below 600 RWHP that should be all I need, and I don't beat on my truck either so I'm not planning on a built tranny, just good service/fluids/etc.
__________________
'10 F250 CC/SB FX4 530 HP/1047 Torque (Gearhead Street Tune), lowered/LEVELED, aFe Stage II Si intake, Spartan CAC pipe, powerstroker67 DPF-delete & ceramic coated downpipe, MBRP Cool Duals, AMSOIL oil bypass, DieselSite coolant bypass, PowerStroke Connection CCV kit, Fumoto oil drain valve, PAC Navigation Unlock Interface, Edge CTS, Boston Acoustic SE85s (front & rear), Kicker Solo-Baric L5 12-inch sub with Kenwood KAC-9105C amp, Retro-Solutions 55W Digital 6K HID Headlights & 3K Fog Lights
Old 09-20-2012, 09:27 AM
kylebryan kylebryan is offline
kylebryan is starting off with a positive reputation.
im looking into this fluid changing right now and ive got a couple questions.
1. i have a job 1 truck but i dont see an external filter. Do some job 1 trucks not have an external filter?
2. how many quarts of fluid do I need to buy if im doing just a drain and refil?
3. if my truck is currently filled with mercon SP would it be ok to top it off with Mercon LV?
4. Should i change the internal filter when i drop the pan?
__________________
SOLD--08 F-250 4x4 CC/SB Spartan 250 tune DPF Delete, AFE PG7 Cold Air Intake. --SOLD
2010 F-250 CC/SB FX4 Lariat. 4" Straight pipe exhaust, Spartan tuner and AFE PG7 intake
Old 09-28-2012, 08:54 PM
Chester_field's Avatar
Chester_field Chester_field is offline
Chester_field is starting off with a positive reputation.
I took mine in a couple of years ago to get it flushed and the told me "it is marked on the transmission not to do a line flush". I prefer the converter to be flushed out.
Blending oil for 20 years I wouldn't mix chemistry's of ATF with out seeing the CofA to make sure you won't having a gelling issue. stick to the manufactures spec's.
__________________
1986 F-250 Supercab 4X4 IDI diesel this May RIP have the parts but no time for it.
1995 F-250 4x4 Regular cab 7.3 Pwrstroke 1/2 million Km's
1994 Mustang GT un-molested
2008 F-250 King Ranch crewcab 2" lift on 37's
Old 09-29-2012, 07:41 AM
rustyculley rustyculley is offline
rustyculley is starting off with a positive reputation.
My dealer down here charges $280.00 for the hot flush, and the service mgr says he believes in it. IDK, since I haven't done it yet.
__________________
Rusty
01 F450 CC 2wd AT
Hutch Mod, EBV Delete
08 F250 4x4
DPF/Cat Delete
GBZ-Tachyon64Plus
Old 09-29-2012, 09:01 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
TomB985
Quote:
Yes you can, the fluids are compatible.
Quote:
Originally Posted by TheDieselStop
From Ford Tech Service bulletin Sep/Oct 2009:
Untitled Document
Tech tips
Approval to Service ALL 5R110 Automatic Transmissions with MERCONŽ LV
Beginning immediately ALL (2003 to 2010 MY) 5R110 automatic transmissions can be serviced with MERCONŽ LV automatic transmission fluid in place of MERCONŽ SP.
Initially only the 2009/10MY 5R110 automatic transmissions were filled and serviced with MERCONŽ LV. In an effort to reduce complexity, Ford Motor Company is allowing all previous model year 5R110 automatic transmissions to be serviced with MERCONŽ LV automatic transmission fluid. This pertains to top off as well as fluid replacement. Mixing of MERCONŽ LV and MERCONŽ SP in the 5R110 transmission is acceptable. Extensive testing has been performed to insure there are no functional or durability concerns with the use of MERCONŽ LV in the 5R110 automatic transmission.
Vehicles affected are F-Series Super Duty trucks (including chassis cab, motorhome, LCF).
Motorcraft MERCONŽ LV is now available in three sizes:
Part Number: XT-10-QLVC - 1 quart
Part Number: XT-10-DLV - 55 gallon drum
Part Number: XT-10-BLV - Bulk
Further information can be found in the Workshop Manual, Section 307-1, Automatic Transmission
Can be found HERE.
__________________
Tom,
Currently truckless.
Most recently: 2013 F150 XLT 4x4 EcoBoost
Moderators, Guidelines, and How They are Enforced
Old 09-29-2012, 11:09 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Had both our Torqueshifts flushed a few weeks back, dealer said not to worry about the filter until you are at higher mileage, first one only has 30K so they just did the hot flush. Second has 105K so they did fluid and filter. Prices have gone down since we had it done on our 6.0L several years ago, well under $300. Used to push $500 IIRC
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'08 CVPI
'09 F150 5.4L
'10 Mustang GT
Old 10-02-2012, 12:43 AM
ssharber's Avatar
ssharber ssharber is offline
ssharber is gaining momentum as a positive member of FTE.ssharber is gaining momentum as a positive member of FTE.
I truly believe in the hot flush. I had it done, supplied the filters, and had the cooling system flushed and refilled for $400.00. The transmission shifted alot smoother afterwards and its been 10,000 miles and no ill effects. I'd say there are surely those out there who have had a bad experience with the flush but not me. YMMV
__________________
Scott
'08 CC Lariat Job#1
Old 10-02-2012, 09:49 AM
strokin83's Avatar
strokin83 strokin83 is offline
strokin83 has a good reputation on FTE.strokin83 has a good reputation on FTE.
I was pretty ticked when I found out the $200 flush at my dealer was just a drain and refill of 8 quarts. Not even changing the filter. I'm not sure what kind of filters you guys have but I used to buy the external filter for my 6.0 at dieselfiltersonline.com for cheap. I think I paid less than $20.I can get Mercon Sp from my Oreilly's for $5 a qt. I changed the filter every 30k and I drained the 8qts in the pan every 15k. My tranny lasted until 279k and that was running 120hp tune at a minimum and towing 6,000 lbs for 85% of my miles. One thing I noticed is that every 15k the fluid came out bright red and clean. I guess the no. 1 killer of auto trannys is heat and the no2 killer is running burnt black fluid that has been broke down by high heat. I worked that truck like a borrowed mule and was more than impressed with that tranny. I think I could have limped it a while longer it was just downshifting hard so I had it rebuilt. Just my .02 boys and girls.
__________________
Zack
2013 Ford F250 6.7. Lariat Oxford white. Stock for now.
2012 Ford F250 6.7 Lariat, Oxford White, Edge CTS,Mprp DPF back.Thunderstruck front bumper.SOLD
2005 Ford F250 6.OH SOLD
1994 Ford F-350 "Ranchin Truck" IDI with ford turbo. Auto.
Old 10-04-2012, 04:16 PM
any insight into my other two questions?
__________________
Old 10-04-2012, 11:08 PM
strokin83's Avatar
1. i have a job 1 truck but i dont see an external filter. Do some job 1 trucks not have an external filter? Not sure on that one.....
2. how many quarts of fluid do I need to buy if im doing just a drain and refil? 8qts
3. if my truck is currently filled with mercon SP would it be ok to top it off with Mercon LV? I'd stick with SP $5 or less at Oreilly's
If you have no external filter then I would recommend changing that for sure.
Good luck
__________________
Zack
Old 10-05-2012, 06:36 PM
slowmans's Avatar
slowmans slowmans is online now
slowmans is gaining momentum as a positive member of FTE.slowmans is gaining momentum as a positive member of FTE.
if you just drop the pan and refill, 8 qts should be plenty.
I wouldn't change the internal filter until 60k
Mercon LV is backwards compatible with SP, you cant get SP anymore unless its old stock.
Tags
2008, 64, add, atf, change, coolers, diesel, f250, flush, ford, front, oil, powerstroke, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. FordŽ is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
