85 2.3 Wont start
Old 04-25-2012, 11:54 PM
Matthew Christiani's Avatar
Matthew Christiani
Matthew Christiani is offline
85 2.3 Wont start
After a head gasket change it simply will not start. I thought it was the ICM but we tested it and its not. I have all the new sensors and air control valve dealies and what not.
I have spark and fuel. How much fuel, i don't know. I have roughly 33lbs of fuel pressure at the rail.
I noticed an elbowed vacuum port that runs underneath the throttle body but it has no hose attached and i dont know where it goes, where it comes from, or what it does. And i don't remember taking it off. We thought maybe THAT lack of vacuum pressure is messing with the Mass Airflow Sensor or something and causing it not to pressurize the fuel system start but i cant find a picture, diagram, or see any place that hose comes from.
another weird thing is that i can spray either into the the throttle body and even that wont start it... im completely out of ideas. what do yall think? Another thing i think it might be is the computer might have gotten moist when i left the truck window down one night. it didnt rain hard, and i doubt it but maybe?
Old 04-26-2012, 06:28 AM
critterf1's Avatar
critterf1
critterf1 is offline
Timing belt correctly installed?
Old 04-27-2012, 10:13 AM
Matthew Christiani
We took the belt of several times because we thought well, just maybe were firing on the exhaust stroke or something. But we werent, and now the timing is like 1 maybe two teeth off. but it should still start, and when it was timed perfect it didnt start anyway.
right now im looking for a vacuum diagram for hoses that go to the throttle body cuz i think im missing one that tells a sensor what to do.
Last edited by Matthew Christiani; 04-27-2012 at 10:15 AM. Reason: additional info
Old 04-27-2012, 10:37 PM
critterf1's Avatar
critterf1
1 or 2 teeth off with fouled plugs will not start.
Budlight67
1983 - 2012 Ranger & B-Series
04-10-2016 11:12 AM
Adolfo Dougy Sanchez
Modular V8 (4.6L, 5.4L)
03-28-2015 07:08 PM
mark169
09-04-2007 11:19 PM
70_f100
04-01-2007 11:02 PM
fasteddie
02-24-2003 11:01 PM
Quick Reply: 85 2.3 Wont start
