Won't start after new Distributor install?
Old 04-23-2012, 04:25 PM
JYP_66F100's Avatar
JYP_66F100
JYP_66F100 is offline
Angry Won't start after new Distributor install?
<style type="text/css"> <!-- @page { margin: 0.79in } P { margin-bottom: 0.08in } --> </style> Bare with me fellows I am new to the Forum and to this site.
I have been a Ford fan for years I grew up learning to drive in a 61 uni-body pickup.
I have a 1966 Ford F100 with 352 5.8L V8, with four on the floor.
I recently installed a Pertronix Distributor with a Flamthrower Coil and a new 1.6 ohm Ballast Resister. The reason I replaced the original Distributor was because of a cracked housing, on the distributor, which I have never seen before, yet there is was. Since I did that I figured I would replace the coil. I followed the instructions to the tee, yet I am having trouble starting. I acts like it is not getting enough “spark”? I have an Edelbrock ASV 750 Carb on it and it is getting plenty of Fuel.
It sputters and coughs, Yet it won't fire/start!
Any suggestions would be appreciated.
JYP
Old 04-23-2012, 04:51 PM
Mikulh's Avatar
Mikulh
Mikulh is offline
I have a couple of thoughts...
1. I don't think the flamethrower coils require a ballast resistor...the one I installed in my '67 mustang didn't. I don't think adding one would cause the problem you're describing, but it may not be helping the situation.
2. Do you think you might have installed the distributor off by a tooth?... it's easy to do.
Old 04-23-2012, 08:41 PM
garbz2's Avatar
garbz2
garbz2 is offline
Start over and make sure the engine is in time.
Number one TDC on the compression stroke.
Pull the valve cover and make sure.
Sounds like you are a tooth or two off on the timing.
Garbz
Old 04-23-2012, 10:04 PM
birdhaus's Avatar
birdhaus
birdhaus is offline
I have the same distributor / coil on my 352, recently installed, I did have to find top dead center, pulled #1 plug and bumped it until the paper towel plug I made flew out...
Makes a lot of spark.. you can gap your spark plugs wider too...
Old 04-23-2012, 11:10 PM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
Wait a second. I assume you used one of their Billet distributors which is to be used with a Flamethrower II coil of 0.6 ohms of resistance. That is the internal resistance of their coil unlike our standard Ford coils which need external resistance.
So I am going to make an assumption here. You have a 1.6 ohm ballast resistor on top of their 0.6 ohm internally resistance coil. A further wild guess deals with the stock Ford pink wire which is adding more resistance from switch to coil. Lots of resistance from what I am guessing on the info you supplied. I would then bet you are nowhere close to 11v at the coil when the ignition is in the start position. You are probably under 9v at the coil (+) which means the engine will never start.
So run a jumper wire from battery to the red ignitor wire and start. A volt meter can verify your voltage as I have gotten real good at doing that on a Mopar engine switching out one electronic system for another. If this test works then dump the ballast resistor (mandatory) and bypass the pink wire which is easy and get 12v to (+) coil terminal.
Old 04-24-2012, 11:16 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
ALL 1960/72 FoMoCo vehicles already have a resistor, this:
COLF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37)
61.49" long / Color coded pink / 1.30-1.40 ohms resistance / #20 gauge wire.
Why would it be necessary to install a ballast resistor since the truck already has this resistor wire?
Old 04-24-2012, 10:17 PM
OldHarley's Avatar
OldHarley
OldHarley is offline
Originally Posted by tbm3fan
So I am going to make an assumption here. You have a 1.6 ohm ballast resistor on top of their 0.6 ohm internally resistance coil. A further wild guess deals with the stock Ford pink wire which is adding more resistance from switch to coil I am afraid, Grasshopper, that you are forgetting the resistance wire does not come into play during starting since a full 12v is delivered to the coil from the "I" solenoid terminal during starting.Lots of resistance from what I am guessing on the info you supplied. I would then bet you are nowhere close to 11v at the coil when the ignition is in the start position. You are probably under 9v at the coil (+) which means the engine will never start.
I like garbz2/mikulh's 'off by a tooth' answer, better.
Old 04-25-2012, 01:31 AM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
You're right, my bad just wasn't thinking clearly. However with the ballast resistor in place anything is now possible. Combine this with the fact that no coil gets 12V during start even with the resistor wire bypassed. Did too much voltage testing in order to learn that. Between resistance in the start wire and old wiring you might get only 9V in start from some cars. The ballast resistor could easily drop him under 9V since my Mopar, with ballast resistor, only saw 9V at start. Bypassing that resistor and I get 11V at start. Easier to test this first before pulling off a water pump and timing cover.
Old 04-25-2012, 09:37 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
If the new ballast resistor was installed right before the coil, then yes that would reduce voltage in start position. Being off a tooth, 180* out, firing order incorrect still are all good possibilities. Do not understand reasoning behind pulling timing cover and water pump.
Old 04-25-2012, 10:05 PM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
I was reading garbz2 and wasn't paying attention to his off a tooth remark. He was talking distributor and I was thinking timing chain. How I came up with that is the bigger mystery...
Old 04-27-2012, 02:52 PM
JYP_66F100's Avatar
JYP_66F100
Thanks Gentlemen, I will endeavor to check all possibilities this weekend. Much appreciated.
JosePrado
09-07-2017 11:56 AM
JGuillen99
01-09-2016 05:40 AM
jshad101
06-27-2014 03:45 PM
circllb
02-19-2009 09:06 PM
bonnieslaw
12-14-2003 04:30 PM
Quick Reply: Won't start after new Distributor install?
