did my fuel pump go out???
Old 04-15-2012, 01:25 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
Are you getting a Wait To Start light? is the tach moving while cranking?
EDIT: you beat me again....
  #47
Old 04-15-2012, 01:41 PM
landmobile's Avatar
landmobile
landmobile is offline
You mentioned a few times that there was only 6V at the pump. That is no good. There are 2 wires going to the fuel pump, one is ground and the other supplies 12V, which you should see for about 20 seconds after key is turned on.
Fuse # 19 (20A) in the under hood fuse box supplies power to the fuel pump relay which then sends power to the fuel pump. There is also a fuel inertia cutoff switch located behind the passenger side kick panel which interrupts power to the pump in the event of a crash.
Chris
  #48
Old 04-15-2012, 02:17 PM
66ca's Avatar
66ca
66ca is offline
ok, its running. here is what i did to the fuses.....
on my fuse box, the #16 slot, which is the 4th big fuse on the passenger side of the box. its a 30amp.
and the #19 slot, the 7th big fuse on that same side. its a 20amp.
Both were blown. Dont know why. One of them corrected the problem, and im not sure what the other one was for.
  #49
Old 04-15-2012, 02:21 PM
landmobile's Avatar
landmobile
Fuse #19 is for the fuel pump, #16 is for the trailer battery charge relay. Glad to hear it's running.
  #50
Old 04-15-2012, 02:24 PM
66ca's Avatar
66ca
66ca is offline
thank all of you guys for your help....couldnt have done it without yall
  #51
Old 04-15-2012, 04:07 PM
Orezona's Avatar
Orezona
Orezona is offline
Disconnect your fuel bowl heater. Common problem. Next time you change your fuel filter look in the bottom of the bowl. You will probably see the coil heater is burnt out.
  #52
Old 04-15-2012, 04:10 PM
66ca's Avatar
66ca
66ca is offline
How do I disconnect it?
  #53
Old 04-15-2012, 04:43 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
On the back of the fuel bowl you'll see an elec plug, just unplug and put a piece of electrical tape around it. It will disable your water in fuel light also, so drain it once a month just incase of water. The heater itself is pretty much useless, and could leave you stranded if/when it shorts out....which you know already... Glad you got it fixed.
sand1
10-22-2016 06:05 AM
Nolo263
08-04-2013 10:01 PM
sc0r1a
08-20-2012 08:05 AM
Big Brew
1999 to 2016 Super Duty
07-18-2009 10:37 PM
BUSTMUP
11-21-2005 04:26 PM
Quick Reply: did my fuel pump go out???
