gas tank/gauge ?
Old 04-12-2012, 11:07 AM
CopenGrizz01's Avatar
CopenGrizz01
CopenGrizz01 is offline
gas tank/gauge ?
Alright I've been wondering this for awhile. First off I have a 1980 f100 4.9l auto and if I'm right it has a 19g tank. When I shut the truck off the gas guage pin or needle goes below the empty mark. So I'm wondering how many gallons are still in the tank after the empty mark. On my truck the needle goes about a quater below the empty mark. But I'm to scared to drive it once its at the empty mark cause I don't want to run out of gas but if there's still a couple gallons in there then I wouldn't have to worry bout it.
Old 04-12-2012, 02:52 PM
1986F150six's Avatar
1986F150six
1986F150six is offline
Is your truck short or long wheel base and does it just have one tank?
Old 04-12-2012, 02:56 PM
CopenGrizz01
It has one tank not sure if its short wheel base or not
Old 04-12-2012, 03:00 PM
1986F150six
Is the bed 8 ft long or about 6 1/2 ft?
If a side mount tank [driver's side under the bed near the driver's seat], it will hold 16 gallons if it is the 6 1/2 ft bed and it will hold 19 gallons if it is the 8 ft bed.
Old 04-12-2012, 03:01 PM
CopenGrizz01
It's 8 ft long
Old 04-12-2012, 03:17 PM
BullyBlue85's Avatar
BullyBlue85
BullyBlue85 is offline
You could drive it until the needle reaches the empty mark, then hit the trip odometer and keep driving until you run out of gas, then record how many miles you went after "empty". Just make sure you have a spare gas can thats full and some starter fluid to start your truck back up. Then you'll know roughly how many miles you can go before you're completely out of gas.
If you know your average mpg then you can divide the number of miles after "empty" by your mpg and that will tell you approximately how many gallons are left in your tank after you hit the empty mark. For example, if you went 50 miles after you hit empty and your truck gets 10 mpg, then you have 5 gallons in your tank after the empty mark.
Hope that helps.
Old 04-12-2012, 03:21 PM
1986F150six
If still factory correct, it should be 19 gallons. If you have been filling it up at 1/4 tank and it take 14 gallons, you should have 5 gallons left. Carry a gas tank [the one you use for your lawn mower] with you for security [just in case you go too far] and drive 30-45 miles after you reach the 1/4 mark and then refill. If now on empty and it takes 17 gallons to refill, you have 2 gallons left when indicating empty.
Oops! I'm too slow. I see that BullyBlue85 beat me to the punch!
Old 04-12-2012, 03:47 PM
CopenGrizz01
I think my guage is messed up cause last week I put 40$ in it and that gave me 9.6 gallons and the guage was showing it was full
Old 04-12-2012, 03:48 PM
CopenGrizz01
Forgot to mention tht it was on empty when I put the 40$ in it
Old 04-12-2012, 04:52 PM
82f100460's Avatar
82f100460
82f100460 is offline
When you turn your truck off and the needle goes all the way down, this is not indicitive of where your "empty" will be. This just means you removed voltage from the sending unit and therefore the gage goes away....
I hope this is not what confusing you. With the truck off, pay no attention to what the gage reads.
Old 04-14-2012, 12:54 PM
BullyBlue85
Haha yea the forum doesn't show new posts in real time, it's all good advice though.
Old 04-14-2012, 12:58 PM
BullyBlue85
Mine does something similar. It will read empty unless the tank is more than half full. I need to check the sending unit.
Old 04-14-2012, 07:39 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Originally Posted by BullyBlue85
Haha yea the forum doesn't show new posts in real time...
Use FTE Live for that.
Old 04-14-2012, 10:50 PM
klricks's Avatar
klricks
klricks is offline
These fuel systems are not all that linear. My gauge stays on full for 75 miles then drops like a rock. This kind of behavior is not all that uncommon for any make and model of car though some are better than others.
Due to space constraints most tanks can not be made into a perfect square or cylinder. That makes it difficult to design a sender / gauge to work perfectly with the typical odd shaped tank designs.
They also do not take into account overfilling the tank. You can get a couple of extra gallons in the filler tube.
You could drain your tank and then put fuel back in 4 or 5 or so gallons at at time and watch where the gauge ends up with each inclement. If you do this be sure to wait several minutes between each addition of fuel.
67galax
03-20-2015 01:30 PM
JGreen236
05-21-2010 10:30 AM
billy12360
03-21-2008 12:08 AM
Ratsmoker
01-26-2002 08:29 PM
Quick Reply: gas tank/gauge ?
