2002 F-150 ac problem
Old 04-11-2012, 02:07 PM
Jterr's Avatar
Jterr
Jterr is offline
How do I get the ac control switch out of the dash? Something must have come loose as I only get cold air or heat to the windshield...
Old 04-11-2012, 05:08 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
You might want to check the FAQs in the HVAC section first....
Old 04-12-2012, 09:47 AM
Jterr's Avatar
Jterr
Jterr is offline
Where might that be? I can't find a HVAC section...
Thanks
Old 04-12-2012, 04:35 PM
projectSHO89
HVAC= Heating, Ventilation, & Air Conditioning. Any forum sections have titles that look like that?
Old 04-12-2012, 05:55 PM
RebColonel's Avatar
RebColonel
RebColonel is offline
I don't remember what the dash looks like in a 2002 model if it's anything like my 1999
the radio surround just pops off and the heater/ac panel is held in by screws.
Old 04-12-2012, 07:48 PM
Jterr's Avatar
Jterr
Jterr is offline
Got it , must be something else as all looks ok; as much as I can see. Need to check someplace else
Thanks
Old 04-13-2012, 12:03 PM
RebColonel's Avatar
RebColonel
Possible loss of vacuum to dash or blend air door. The blend air door is notorious about breaking on these models. If it is the blend air door you will have 2 choices. Either remove the dash to replace it or use a Heater Treater repair kit. I personaly would use the kit.
Look on You Tube for the video on how to. You can order them online.
Old 04-13-2012, 01:50 PM
Jterr's Avatar
Jterr
Jterr is offline
I don't have a blend door problem; as I get hot and cold air. It is the changing from, say defrost to blowing out the dash vents. Nothing happens when I change the settings just keeps blowing out the defrost vents.
Thanks
Old 04-13-2012, 09:49 PM
critterf1's Avatar
critterf1
critterf1 is offline
Check the vacuum supply line.
Old 08-22-2012, 08:39 AM
AngelasFord's Avatar
AngelasFord
AngelasFord is offline
Thanks
I have the same problem,, I have checked the valves,, one was crimped as it had melted,,, still no luck. As I was driving yesterday I would hit bump, and it would switch to the dash, hit another bump back to the vents, then no cool air,, now its stuck in the dash
Old 08-22-2012, 08:43 AM
AngelasFord
ac acting up again... help!
I have a 2002 f-150,,, I hate this truck, but I cant afford to replace it, so have to keep it running.
Yesterday while driving home, I would hit a bump and the ac would switchto the dash,, no cool air,,, hit another bump, switch to the vents,,, little cool air,, hit a bump and then back. Now its stuck in the vents with no cool air. I checked the vacume lines,,, had probs here before,,, fixed them,,, still nothing,,, stuck onthe dash....
please help, before I take it to a mechanic. I would love to fix and sell the thing,,,
Old 08-22-2012, 09:58 AM
Jterr's Avatar
Jterr
Jterr is offline
I finally found the problem. It was a small vacuum line in the engine compartment. Fixed doing fine.
Thanks all
Old 08-22-2012, 10:09 AM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
'When function door is in defrost position, air inlet door vacuum control motor is at no vacuum, admitting only outside air into passenger compartment. Panel/floor door and panel/defrost vacuum control motors are at no vacuum, directing air airflow to defrost duct and side window demisters. Temperature can be adjusted to heat or cool air below outside temperature. A/C compressor will operate if outside temperature is above approximately 43*F (6*C). Blower motors is On.'
You're either not getting a vacuum source to the Panel/Defrost Vacuum Actuator or the actuator's diaphragm has a hole in it.
Old 08-22-2012, 10:11 AM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
LOL, just before I typed this.
sneltyr
03-14-2013 10:59 PM
wickedbusa
S. California Chapter
15
08-23-2012 11:10 PM
elcamino12sec
12-13-2006 05:45 AM
v10kenj
1999 to 2016 Super Duty
12-15-2003 03:21 PM
hotstik
01-08-2003 08:30 PM
Quick Reply: 2002 F-150 ac problem
