1997 ford f150 no spark wont start!
Old 04-01-2012, 11:55 PM
Zack12's Avatar
Zack12
Zack12 is offline
I recently took a 4.6 from a 98 e-150 van and put in a 1997 f 150. put new oil pump, bearings, and rings. got everything hooked up and ready to roll. turn over but no spark to any cyl. any suggestions on what it might be.
Old 04-02-2012, 06:54 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Could be any of a number of things. Start by making certain all your harness connectors are properly connected.
Old 04-02-2012, 07:51 PM
Zack12's Avatar
Zack12
Zack12 is offline
i have checked many times every thing is plugged in and right. replaced crank sensor still nothing.
Old 04-02-2012, 08:11 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,425 Likes on 2,340 Posts
check to see if you have power to your injectors and coils with the key on. If not find out why. Fuse or Fuselink cable?
Old 04-03-2012, 09:08 PM
Zack12's Avatar
Zack12
Zack12 is offline
have no power to fuel pump, injectors or coils. have checked fuses cant seem to find any bad ones.
Old 04-03-2012, 09:38 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Make sure the super fuse on the firewall by the battery is wired correctly. You can easily put the Y connector on backwards and have no power.
Old 04-03-2012, 09:45 PM
canacka's Avatar
canacka
canacka is offline
I had a similar problem a year ago. I thought it had to be this, then that, then since that didn't work it must be this. Nope, figured it out when I bumped the fuse box with my leg. The fuse for the ignition was not blown, BUT the little metal clips inside the fuse box were loosened. All I needed to do was pull the cover off of the fuse box and squeeze the clip with needle nose. Spent a butt load of money to fix it when it ended up being a $0 fix! ARGH!
Old 04-03-2012, 09:54 PM
Zack12's Avatar
Zack12
Zack12 is offline
is that the y looking thing that hooks to the solenoid?
Old 04-03-2012, 10:00 PM
Zack12's Avatar
Zack12
Zack12 is offline
the fuse box inside the truck?
Old 04-03-2012, 11:02 PM
Papa Tiger's Avatar
Papa Tiger
Check for a bad PCM power diode. This will fire the PCM relay and also the pump relay.
Old 04-03-2012, 11:53 PM
Zack12's Avatar
Zack12
Zack12 is offline
got it! it was the the same deal the little metal clips that power the fuse was lose tightened it hit the key and fired off. thanks for all the help
Old 04-04-2012, 07:24 AM
canacka's Avatar
canacka
canacka is offline
Your welcome!
Old 04-04-2012, 12:04 PM
Papa Tiger's Avatar
Papa Tiger
If you notice any damage just order a new/used one toput in.
Old 04-08-2012, 05:29 PM
Joe_G's Avatar
Joe_G
Joe_G is offline
Thank you for posting this! This was my problem too. You saved me a bunch if time!
Old 06-27-2015, 05:16 PM
Ericos's Avatar
Ericos
Ericos is offline
Canacka, I cannot thank you enough for posting this. I had the exact same problem and was beginning to be so frustrated until I searched for help. You were absolutely correct. Fuse number 30 was loose and did not seat in the fuse jacket correctly. I corrected it with a piece of wire and BAM!! Started right up. .
I'm am thankful bro!
Quick Reply: 1997 ford f150 no spark wont start!
