Back to my 2012 F250 Payload
The stuff I read is that payload is 3300 lbs. But I looked on drivers side door pillar and based on six occupants and cargo my "safe" payload is 2339 lbs. If pin weight of fiver is 2100 lbs. and hitch weighs 200 lbs then I am at max capacity assuming I am carrying four other people and some cargo.
What average weight of occupants is assumed?
Maybe someone can give me actual scenario of what extra lbs. I have to play with between hitch pin wt. and payload (either 2339 or 3300 lbs.)
When I read 3,300# payload in your other thread, I wondered where you got that number. Because it seems pretty high to me. Is payload printed on your door pillar sticker? If you've got a GVWR of 10,000# (the highest possible for an F250) and a 3,300# payload rating, that means your truck only weighs 6,700#. Which might be true of a XL gasser regular cab. But not true of a Lariat diesel crewcab.
As I understand it, GVWR is figured with one driver that weighs 150#, and a full tank of fuel, no passengers, no optional equipment. Subtract the actual weight of the truck from the GVWR, and that gives you the payload. In other words, whatever is left over from the GVWR is available payload.
I think the best thing you can do is fill up with fuel and head to the scales. Weigh the truck with you in it. Subtract that from the GVWR, and that is your actual net payload.
Perhaps more important is to weigh just your rear axle. Then check your RAWR on the door sticker. Do the math, and that will tell you how much you can put on the fiver hitch. Almost all of the trailer pin weight will be on the rear axle, and a neglible amount transfers to the front axle. These numbers are usually in your favor when it comes to fivers/gooseneck. You may be over the GVWR, but still within each axle weight, which is what matters most.
Overweight
If the sticker says 2339 and the fiver is 2100, you are going to be illegal. If you are within axle rating, you may not be unsafe, but you will be illegal. Is the 2100 pin weight, "published" or actually weighed loaded and ready to go?
Looks like you should scale the truck, fiver and each axle if you can.....
If you don't look overloaded, you won't have a legal issue with a recreational trailer.
You're splitting hairs. 2-300 pounds extra is not going to break anything. His truck can handle the pin weight without issues. I'd install air bags on the rear and hit the road.
It gets pretty complicated in last years. The laws about heavy pickups are very old, but they were not enforced till the states start going bankrupt and the Police was send to generate more revenue.
In CA any vehicle above 10,000 lb GVW is required to have commercial CA number and commercial insurance. Lot of states follow as this bring big money for the state. You can get away with it if you register your truck as an RV and never remove camper shell, or 5th wheel hitch.
That said, DOT never check the vehicle GCVW and as long as you pay the registration for the weight you are carrying and don't pose road hazard -they don't care.
If you pay attention on the road, you will notice lot of 1-ton pickups pulling 30,000 lb gooseneck trailers COMMERCIALLY.
GreyRanch
Toy Hauler Towing; Fifth Wheel & Bumper Pull
17
07-26-2010 07:47 AM
gerg
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-01-2005 07:23 PM
