HELP,C.V. ifs install bolt holes
Old 03-22-2012, 08:23 AM
mkrog's Avatar
mkrog
mkrog is offline
Need some help from anybody that's installed a C.V. IFS.How did you get the holes need in the frame to line up top to bottom.This on a 57 F 100.
Old 03-22-2012, 12:51 PM
fast58's Avatar
fast58
fast58 is offline
I jacked the front suspension up until the "pegs" touched the frame. Then I aligned the whole suspension left and right along with spacing from the front. After I got the front suspension sitting the way I wanted it, I marked the holes on the bottom of the frame (through the factory holes in the CV IFS) with a paint pen. Then I bolted the top part of the front suspension on (the part that kind of folds over on top of the frame ). Then I marked those holes as well with a paint pen. After I got all the holes marked I drilled them out.
NOTE: Once I got the holes drilled out, the sleeves fit very tight and had no "wiggle room" to fine tune the adjustment; so I cut the holes out a little larger in diameter with a torch to accommodate. I also used the 12"-15" section of frame off of the CV that the suspension bolted through. You can check my Buildup thread to get more details.
Hope this helps!
keisha9
08-15-2013 02:58 PM
carnut122
04-10-2009 04:38 PM
kld1958
07-20-2007 08:59 AM
hardway
05-04-2007 04:07 AM
1low50
06-26-2004 11:48 PM
Quick Reply: HELP,C.V. ifs install bolt holes
