Oil Filter
Oil Filter
I have been having a heck of a time finding the Part number for a moto craft oil filter for my 1993 Bronco 5.8. I have the fram number, but dont want to use one on it.
Anybody help me out? BTW ford's motocraft site is messed up, when through there process only for it to tell me they didnt have anything that matched my criteria.
Anyways. Help would be appreciated.
you can find it here...
Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com
great OE parts search tool.... just enter your VIN.... my 5.8 filter is 6731 (FL-820)
I don't think much changed from 93 to 94 like mine. I just ran the 93 on that site and I get the same error. But if you change the year to 94 5.8 you will get the result.
FL1A...
300 - FL1A
302 - FL1A
351W - FL1A
351m - FL1A
400m - FL1A
460 -FL1A
...and just about every other Ford mill from the mid sixties through the advent of the modular engines near the turn of the century. If you want someone else's P/N for it just cross reference it against the OEM (Motorcraft) FL1A. The ONLY reason the FL820 was used was so that the added depth of the oil cooler ring would not make the oil filter protrude further from the block than the FL1A did without the cooler fitting behind it. The FL820 is physically shorter than the FL1A but otherwise the same. The FL1A can still be used on vehicles with the oil cooler if you can get in in place.
300 - FL1A
302 - FL1A
351W - FL1A
351m - FL1A
400m - FL1A
460 -FL1A
My 94 5.8 had the short filter when I bought it. I measured the length then went to a parts store and measured the FL1A . I decided the FL1A might fit if you did not need room to screw it on and off. I did not know the threads/holes are different. My 94 has the towing package which included the oil cooler under the filter.
supposedly it is a metric/SAE thing...and supposedly the 820s anti-drainback helps with dry oil-less starting...
https://www.ford-trucks.com/forums/8...he-fl-1-a.html
and
https://www.ford-trucks.com/forums/8...s-fl-820s.html
these are from our site and give more info if interested.
and
Christopher2
05-17-2005 07:24 PM
