rack and pinion
So I have your permission? . . . I was looking at cost and keeping my hands busy. Sense my box is selfdestrucking I'll guaranty the steering will be easier. It may or may not turn sharper depending on what rack I use. Plus the option of power steering if I want (I don't). Other sites have recommended a Toyota previa or VW Vanagan because of the location of the steering column in relation to the axle, the Toyota uses a 90 degree box to change the direction of the steering column. Apparently the column is in front of the axle and the rack is behind the axle like ours not sure of the the VW setup. At the local pull a part part would be about $120 (steering column, rack and 90 degree box)
Look, I did not mean to imply you need a "permission" to accomplish this but, I was assuming you wanted something that would not only be doable 9which it is) but be effective as well.....if I may suggest, you can get the oem steering box rebuild kit (including fast steering which would reduce the number of turns by about 20%) by these guys at less than what you are looking to spend on used parts....
Classic Mustang Disc Brake Conversions and Power Steering
While they are not experts per say on the Econo's, I would bet they would have some very good advise on part selection and may even have something that would work with a higher degree of success, etc.
If the rack was mounted to the front axle it would eliminate the bump steer problem. The shaft from the 90 degree box to the rack would have to be a sliding shaft with universal at both ends. The location of the rack would be approximately where the tie rod is now. Still in thinking stage (no cash) but that's what I invision. If I get the parts from local pull a part and fab brackets I should be able to put it together for half of what they want to rebuild a stock box.
JNye
01-24-2019 04:03 AM
