seat belt chime
Old 03-17-2012, 08:36 PM
pdqtimetrialer's Avatar
pdqtimetrialer
pdqtimetrialer is offline
seat belt chime
My 2004 F150 has a weird bug related to the seat belt sensor - it only reads the seat belt condition when the truck is first started, then ignores it the rest of the time. Not a big deal so long as I remember to buckle up before starting it. I tried to do the routine of turning off the chime, but because it doesn't read the seatbelt condition after the key is in the run position, it can't be performed. Likewise, if I start the truck buckled up and then unbuckle once its running, the seatbelt light does not illuminate on the dash.
Certainly an easy enough work around, though rather odd. Any body else ever hear of this? It's not a symptom of anything else, is it?
Old 03-18-2012, 10:26 AM
DieselBeast01's Avatar
DieselBeast01
DieselBeast01 is offline
My dad's 04 did this exact same thing. If you didn't buckle the seatbelt before you started the truck, it would not recognize that you had buckled up. He never did anything about it and just made sure to buckle his belt before starting the truck.
Old 03-18-2012, 06:45 PM
pdqtimetrialer
I played it around with it more today. It seems like the sensor works once the trucks has been running and then turned off again. For a brief moment I thought I would be able to go through the disable chime procedure. Buckled and unbuckled 9 times but never got the air bag light to come on.
Would disabling the sensor be as simple as jumpering two leads together someplace?
Old 03-18-2012, 11:38 PM
DieselBeast01
I'm not sure about that on these trucks. I know that in my 2001 superduty, you just had to disconnect a harness that ran out of the carpet to a plug in the bottom of the seat. It was as simple as that.
I havn't looked under the seat in my f150, but it may have a plug too. I imagine though that if you unplugged it, it would set off some other warning like a light or something.
Ovrpwrd
1999 to 2016 Super Duty
26
02-02-2010 12:07 AM
F2504x4_05
12-29-2004 03:31 PM
82f1504x4
01-23-2004 04:55 AM
PLYUSA
05-06-2003 08:41 PM
Quick Reply: seat belt chime
