f250 83 7.5 (won't start now)
Here's the skinny on my beast.
1983, F250 7.5, automatic.
It wouldn't pass through DEQ, wrong carb.
Replaced carb. Ran fine. But not having tags, I didn't drive it. But I know it ran fine. As it's not my main driver, I haven't necessarily been too concerned about it.
I had a mechanic adjust the carb, and it ran strong. Moved it out into the street probably a month ago (?). It has plenty of gas, and sits in the street nose down.
Today i decided I would try to start it. It turns over plenty fast, but doesn't catch.
If I put starter fluid in it, it will turn over and catch and run until it dies when the starter fluid obviously dies off.
I'm wondering if it's a fuel pump or fuel filter issue. The filter occasionally hums when I start (and sometimes will stay humming after i turn off the truck), but mostly doesn't hum.
Earlier, when I was fixing the truck (from a previous operation) I tried replacing the fuel pump (?) solenoid (? I think thats the name...little green box in the engine compartment), but that didn't make a lick of difference.
I think once I get the beast fixed, passed through DEQ, I'm going to sell it. It's not like I dislike the truck, it just turned out I don't need it like I thought I would.
Any suggestions (from my vague descriptions)?
I'm hoping it's fuel pump, because it would make sense. Could it be the sending unit? I know both my tanks barely read accurate (and I just remembered that the previous owner said that when the truck is using the BACK tank, that it would not work great on a hill unless you had a majority of a tank in it).
dan
dan
berry1234
02-05-2011 04:16 PM
EvansE.S.
18
01-23-2011 04:47 PM
