Airbag light flashing
Old 03-14-2012, 09:03 AM
ZachF's Avatar
ZachF
ZachF is offline
Angry Airbag light flashing
I just did the odometer fix and put a new led in the headlight switch in my 2001 F150 and now my air bag light is flashing, it flashes 2 times and then 7 times but when I turn the pass airbag off the light goes off. Any ideas?
Old 03-14-2012, 09:17 AM
00GT's Avatar
00GT
00GT is offline
The air bag light work in the dash? A burned out bulb will throw a code
Old 03-14-2012, 09:37 AM
ZachF's Avatar
ZachF
ZachF is offline
When the key in the airbag switch is set to on the off light in the airbag switch is off, (duh) and when the switch is set to off the light is on but when I turn the ignition to run the light doesn't turn on for two seconds like it used to. Before I took the dash apart the light used to turn on for around two seconds when I turned the ignition to run and now it doesn't.
Old 03-14-2012, 10:35 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
SEARCH keyword "+LFC +27" for several dozen previous posts/threads.
Old 03-15-2012, 09:16 AM
ZachF's Avatar
ZachF
ZachF is offline
Thanks! It was the bulb.
lordphantom
1983 - 2012 Ranger & B-Series
03-16-2014 07:09 PM
nrskel78
1999 to 2016 Super Duty
09-08-2013 06:02 AM
naiku
1997 - 2003 F150
03-11-2011 06:34 PM
baslerxlt
1997 - 2003 F150
12-20-2008 01:17 PM
jayhawkfan
02-19-2004 03:29 PM
Quick Reply: Airbag light flashing
