Intermittent starting problem.
Old 03-13-2012, 11:37 PM
SLUF681's Avatar
SLUF681
SLUF681 is offline
Question Intermittent starting problem.
My cousin called me today with a problem. I'll give as such vehicle info as possible.
2001 F250, 7.3L, Auto, 2WD, Ext. cab, Lariat, approx. 115k. To my knowledge (and his) there is no tuner/chip on the truck, although I have seen a very small puff of black smoke when it downshifts.
He went out to start it to go to work and it wouldn't start. The starter turns he engine over fine, the tach is moving, but he said he couldn't see white smoke. While cracking, it sounds as if a relay is clicking furiously under the dash. After trying to start it several times, the clicking stopped and the truck started fine. It may not do it for several days, but seems to happen every couple of days. Any ideas?
Old 03-14-2012, 01:00 PM
01PS's Avatar
01PS
01PS is offline
Sounds like what mine sounded like when my batteries went south. What was the tach reading when this happens? Have him clean his batt terminals and check connections.
Old 03-14-2012, 01:34 PM
SLUF681's Avatar
SLUF681
SLUF681 is offline
He said the tach was moving. To what rpm I don't know. He said it was cranking strongly, though he did say his batteries were super corroded. I tried to get him to take 5 minutes to clean them and put some no-a-lox (sp?) on them.
Old 03-14-2012, 01:40 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Sounds to me like it starts after the GPR releases. That is probably when the required 10.5 volts to start is available.
It is most likely dropping below that voltage while GPR is operated.
Old 03-14-2012, 01:48 PM
SLUF681's Avatar
SLUF681
SLUF681 is offline
Ooh, good point. I hadn't thought about that. That is a VERY good possibility.
Old 03-14-2012, 02:05 PM
PaysonPSD's Avatar
PaysonPSD
I was on the phone with a member who had a no start problem. Under 10 volts while cranking.
Had him lift one of the control leads off the GPR so it wouldn't operate. Truck started right up.
Old 03-14-2012, 02:38 PM
SLUF681's Avatar
SLUF681
SLUF681 is offline
Battery terminals are clean now. I guess we'll see how it goes.
Old 03-14-2012, 02:48 PM
PaysonPSD's Avatar
PaysonPSD
Have him check for 10.5 volts when he first starts cranking.
Kyle017.3
1999 to 2016 Super Duty
04-14-2017 11:51 AM
KCMAGERS
11-29-2009 03:48 PM
chuck641
28
11-15-2008 02:30 PM
mmmPowerStroke
15
12-21-2005 10:48 PM
sdpj
09-26-2005 12:44 AM
Quick Reply: Intermittent starting problem.
