2011 to 2019 Explorer Discuss the 2011 to 2019 Explorer
Tow Hitch
Old 03-12-2012, 08:07 AM
77_150's Avatar
77_150
77_150 is offline
Tow Hitch
I should have had the tow hitch/assembly added when I bought it, but did not so now I find myself in the situation where I need it. Just wondering if anyone knows if this is something that is easy to do (meaning - me do the work) or should I let Ford do it for $150? The docs that I have read said it bolts right in without any modification at all. I do not need to wiring harness right now since this will mainly be used to haul bikes.
Any ideas?
Old 04-04-2012, 10:52 AM
kmonty2's Avatar
kmonty2
kmonty2 is offline
Well you only needs the lights if your are towing a trailer. Sounds like a good price for the hitch installed and I would let them put the lights in at the same time. If you don't you will want to hook up a trailer the next day. I need to get put on mine too, but I got mine off the lot so no option at the time of delivery foes me to get one.
Old 04-05-2012, 08:55 AM
77_150's Avatar
77_150
77_150 is offline
Well, that price is just the installation cost and not the hitch. The hitch can run between $300 and $465 for the Ford version. I ended up buying a Curt class 3 hitch for $140 and paid a local shop $45 to have it installed. Looks really good and should be able to handle hauling 2 30lb bikes
Thanks for your response
Old 12-04-2012, 06:46 PM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
Yep! Curt is the way to go. $146 on Ebay delivered. Easy install. No drilling or cutting. Do it yourself and earn the right to brag about the great look. Good luck, Jag
Old 12-13-2012, 05:06 AM
tdappleman's Avatar
tdappleman
tdappleman is offline
I ordered and installed the ehitches one for a customer which I think is the Hidden Hitch. Easy install and the wiring was plug and play. Hitch, wiring and ball mount was 300 with free shipping. They have a video online which shows the install. I wanted factory on mine but wouldn't have hesitated to use them again if I had needed to.
Old 07-15-2013, 09:18 PM
Awake79's Avatar
Awake79
Awake79 is offline
What years are your Explorers? I have a 2011 XLT, and have the same problem; mine doesn't have the factory tow package, but now I want/need one installed. I didn't know if the receiver and wiring harness was a factory only thing, or if my local dealer's service department could do it? I went by the dealership tonight and saw all the new ones have a hidden hitch inside the bumper, and figured I would have to get the new bumper as well. Any info is great! Thank you all!
Old 07-16-2013, 07:15 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Aftermarket is cheaper and better as others have posted
We actually got the hitch.and.will probably never use it ;_)
Old 07-16-2013, 07:16 AM
jdadamsjr's Avatar
jdadamsjr
Old 07-16-2013, 08:00 AM
Awake79's Avatar
Awake79
Awake79 is offline
I guess Im just not mechanically inclinded enough. After looking at the rear end I didn't see how I'd be able to mount one, and run the wiring. Appreciate the reply, thanks.
Old 07-24-2013, 09:25 PM
tdappleman's Avatar
tdappleman
Old 07-25-2013, 07:26 AM
Awake79's Avatar
Awake79
Awake79 is offline
That is great! Thanks for the info!!! Of course, that still leaves me with the wiring harness, but, baby steps. hahaha! Thanks again, I appreciate it.
Old 07-25-2013, 07:52 AM
LI250's Avatar
LI250
LI250 is offline
I used this. Its labeled as ProSeries but is the same as the Reese. Easy install and it came with the harness.
http://www.ebay.com/itm/2011-2013-FORD-EXPLORER-TRAILER-HITCH-TOW-W-PLUG-PLAY-WIRING-HARNESS-KIT-NEW-/221124697941?pt=Motors_Car_Truck_Parts_Accessories&hash=item337c0f1f55
Old 07-30-2013, 04:14 PM
jschira's Avatar
jschira
jschira is offline
Originally Posted by jdadamsjr
Aftermarket is cheaper and better as others have posted;_)
Aftermarket hitch does not include the engine oil cooler. Factory tow package does.
Old 07-31-2013, 05:57 AM
LI250's Avatar
LI250
LI250 is offline
Agreed but the question is what to do when you didnt get the factory option. I dont believe the price of the hitch from Ford includes the oil cooler. Its the hitch only.
Old 11-17-2013, 06:14 PM
Down South 1's Avatar
Down South 1
Down South 1 is offline
I know the thread is old, I haven't been here much lately since I got rid of my last F-250 Diesel Power Stroke.
I recently bought a 2012 Ford Explorer XLT without a trailer hitch. After recovering what Ford said they wanted to install one for I decided to do what I usually do and buy and aftermarket hitch and install it myself. I bought a Reese from Flebay with the wiring kit.
http://www.ebay.com/itm/REESE-Trailer-Hitch-Wiring-for-2011-2014-Ford-Explorer-Class-3-2-Receiver-/171142835015?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2012%7CModel%3AExplorer&hash=item27d8e86b47&vxp=mtr
My question is, to get full tow ability from this hitch and since I do not have the factory tow package, will I need an add on transmission cooler?
Most of my towing should be about 2000 lbs. I have a 12' tandem axle single wheel trailer. I know, that's short trailer for a tandem axle but I figure the trailer weight is less than 1500 lbs, will have to weigh to be sure. The Golf Cart that I will be hauling is a Club Car electric and from what I read weighs 506 lbs.
Wow, I had at least a couple thousand posts here but it must be time to start over since this shows as my first post.
grampscamper
6.7L Power Stroke Diesel
03-11-2013 05:32 AM
DUKHNTR4LFE
1999 to 2016 Super Duty
09-18-2005 04:02 AM
Steamships
1978 - 1996 Big Bronco
02-10-2005 08:21 PM
holt132
Escape & Escape Hybrid
10-20-2004 06:43 AM
Quick Reply: Tow Hitch
