1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rear Axle Seal Leaking
Old 03-09-2012, 05:27 PM
MauleOne's Avatar
MauleOne
MauleOne is offline
On my e99 F350 the rear axle seal is leaking and causing the brake to be wet.
I started to disassemble the hub but found that there is a special nut holding the hub on to the axle housing.
I have the tool but do not know if the racheting nut has a locking tab or what. I do not want to brake something by wrenching on it.
My parts supplier thinks the axle is a Ford unit but wants the old seal to make sure.
Any help would be appreciated. Thanks
Old 03-09-2012, 05:32 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
I've never messed with those seals yet so I'm fairly clueless myself. I wonder if this link would be helpful
Welcome to camodown's Rear Hub Seals and Parking Brake repairs
Hope this helps.
Old 03-09-2012, 06:43 PM
1973Ford2004's Avatar
1973Ford2004
1973Ford2004 is offline
I just posted this to another poster the other day, check your vent tube nipple, it may be clogged, mine was and my axle seal was leaking, luckily I haven't had to tear it apart yet on my 2004, I cleared the clog and the problem has gone away, good luck
Old 03-10-2012, 08:07 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Push in with the socket when turning the nut.
Old 03-10-2012, 05:59 PM
MauleOne's Avatar
MauleOne
MauleOne is offline
Axle Seal
Well that worked fine until I went to bleed the brakes and the bleed port broke off the left hand brake.
Now I am putting a replacement unit on and hoping that the one on the right hand brake doesn't break off.
mikecwik
04-12-2021 05:36 PM
ebbtide
01-18-2019 05:12 PM
dashell
04-02-2018 09:31 PM
Eric Kropp
10-28-2014 05:33 PM
02superstroker
03-02-2006 05:11 PM
Quick Reply: Rear Axle Seal Leaking
