Dash Wiring Diagram
Old 03-08-2012, 03:27 PM
nick_lozier's Avatar
nick_lozier
nick_lozier is offline
Dash Wiring Diagram
Im looking for a wiring diagram of the dash. My heater isnt working the Blinkers inside are solid however the blinkers still work. and the windshield wipers wont work I think this is all related by a common harness would someone help me please
My truck is a 1995 F-Super Duty with the 7.3 powerstroke
Old 03-08-2012, 03:45 PM
Hussler's Avatar
Hussler
Hussler is offline
Welcome to FTE ...
This should get you going in the right direction.
1996 Bronco/F-Series Workshop Manual
Old 03-08-2012, 04:45 PM
nick_lozier
thank you but it dosnt get in to the dash wiring from all I looked at
Old 03-08-2012, 07:04 PM
Ken_C's Avatar
Ken_C
Ken_C is offline
I posted a bunch of diagrams for a 97 f350 not sure if it will help. i was able to use some of them on my f250 and they did work for me.
https://www.ford-trucks.com/forums/1...o-links-4.html
Old 03-08-2012, 07:37 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
The turn signal and wiper problem sounds like could be a bad multi-function switch. Is the heater problem just the blower not working?
Old 03-08-2012, 07:52 PM
nick_lozier
the blower slightly works but barley and the wipers dont work at all except when i turn the ignition on they move like 2 inches then die
Old 03-08-2012, 07:58 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
I'd change the multi-function switch and see if that cures the turn signal and wiper problem, and for the blower, that could be a bad resistor.
Old 03-08-2012, 08:00 PM
nick_lozier
I have bypassed the resistor and jumped it to see if the motor was good all that is good but no power to the blower... and ya i was thinking multi function switch too but the heater thing happened at the same time so i thought it was related
Old 03-08-2012, 08:12 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
With it all happening at the same time it could be a common problem. Maybe there is a short in the multi-function switch that's messin with the blower. I keep refering to the m-f switch cause mine did something similar with the signals and wipers and that's what it was. If you could get one off another truck to try and see if that's it before buying one would be the way to go.
Old 03-08-2012, 08:15 PM
nick_lozier
now the m-f switch you are refering to is the one on the column the turn signal switch?
Old 03-08-2012, 08:19 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Yeah, they're not hard to change.
JD Sanchez
1999 to 2016 Super Duty
08-07-2019 06:29 AM
Builtfordtough001
12-01-2015 09:57 PM
Building_Fords
10-27-2015 08:06 PM
martyanderson10
01-25-2015 05:27 PM
Quick Reply: Dash Wiring Diagram
