Is Prestone compatible with Motorcraft Gold Coolant for 6.0 PSD Excursion?
Old 03-04-2012, 12:35 PM
XS29L9B's Avatar
XS29L9B
XS29L9B is offline
Topic title says it all... Thanks in advance... Auto parts store said it was compatible... Is it?
Old 03-04-2012, 06:20 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Not enough info. There's all kinds of different Prestone coolants out there. Which Prestone are you referring to?
Actually, forget I asked, just go to Walmart or NAPA auto and get Zerex G-05 coolant. It's the same stuff as the Ford "gold" coolant.
Stewart
PS - If it were my 6.0L PSD, I'd flush that "Gold" outta there and refill with an OAT Extended Life Coolant.
Old 03-04-2012, 06:58 PM
XS29L9B's Avatar
XS29L9B
XS29L9B is offline
Stewart,
It was the "all for one", color doesn't matter, coolant... Or so the bottle said...
Also, I saw where Zerex G-05 was the same as MC Gold, but wasn't so sure...
Old 03-04-2012, 07:10 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by XS29L9B
Stewart,
I honestly have no idea what is in that universal "compatible with all types, all colors" Prestone because I will never use it. I'd fill with just tap water before using it.
If you're dead set on using the "gold", just get a jug of the Zerex G-05.
Stewart
Old 03-04-2012, 11:58 PM
kornfanjoe's Avatar
kornfanjoe
kornfanjoe is offline
Stewart,
I would never trust that saying. Diesels need anti cavitation inhibitors to prevent the engine knock scarring the outside of your sleeve, plus the coolant in a 6.0 is very taxed as it cools the engine, the oil, and the exhaust in the egr cooler.
Old 03-08-2012, 04:09 PM
jeeplj8's Avatar
jeeplj8
jeeplj8 is offline
as a general rule never ever mix anything with Ford Gold Collant.
General rule #2, get the Ford crap out of your 6.0. it leads to oil cooler failure. use a stated ELC coolant, Prestone is fine. swap it all out.
Old 06-18-2012, 08:09 PM
Gage2502's Avatar
Gage2502
Gage2502 is offline
So I take it that Zerex G-05 is good to use on my 2005 Ford F250 V10?
Thanks
Old 06-18-2012, 08:21 PM
Stewart_H's Avatar
Stewart_H
Thanks
Yup. Gasser, not a diesel, so you're good to go.
Stewart
Old 06-18-2012, 08:33 PM
AndrewWV's Avatar
AndrewWV
AndrewWV is offline
Originally Posted by Stewart_H
...just go to Walmart or NAPA auto and get Zerex G-05 coolant. It's the same stuff as the Ford "gold" coolant.
I wish it was that easy around here. The last time I looked for Zerex the only place I could find it locally was Grainger. They usually only have a bottle or two on the shelf, so I have to special order it, and they only have the 50/50 prediluted mixture for around $12/gal. It actually works out cheaper to go online or buy genuine Motorcraft from the dealership at $16 - $17/gal.
I'm pretty sure that gold stuff is a HOAT (hybrid) extended life coolant, not that I really know what that means in practical terms, beyond what I've read around the web. I do know the subject of coolants is another online holy war of sorts.
Old 06-18-2012, 08:44 PM
AndrewWV's Avatar
AndrewWV
AndrewWV is offline
Stewart,
Yeah, so Prestone claims, but the auto manufacturers and name brand coolant companies really disagree. I'm pretty sure they are all ethylene glycol based and the major differences are the additives and rust inhibitors they use. I tend to avoid the "all-for-one" types because the most consistent advice I've found warns not to mix different types together.
Old 06-18-2012, 11:33 PM
Stewart_H's Avatar
Stewart_H
Andrew, you're exactly right, it's a H-OAT coolant.
What that means is this: the Ford "gold"/Zerex G-05 Hybrid Organic Acid Technology coolant still contains silicates. Silicate drop out is what causes problems with the 6.0 coolant passages in the oil cooler, and it also eats the water pump seals. That's why Late '99 and up 7.3L PSD owners that had conventional "green" coolant will flush and fill with an OAT ELC, because the "green" has a lot more silicates than the "gold"
You can read more here, where I have a ton more info listed in this thread: Gooch's Coolant Flush Procedure and In-Depth Coolant Information - FTE
Stewart
03pwrstrk
12-16-2009 09:45 PM
vancouverpower
01-18-2006 07:34 PM
crapr6
10-04-2004 09:47 AM
troutman2
24
12-19-2003 04:57 PM
02superstroker
04-12-2003 06:51 AM
Quick Reply: Is Prestone compatible with Motorcraft Gold Coolant for 6.0 PSD Excursion?
