Will these exhaust manifolds work on my '65 F250 / 352?
^ Not from any F100/350 FE. Enlarge the pic, look at the ID prefixes: One is C8AE, t'other is C3SE, these are car manifolds.
Both are from Passenger Cars, the exhaust collectors are in different locations than F100/350 FE exhaust manifolds.
The left (drivers) side 1961/63 T-B (C3SE) manifold may not clear the trucks steering box.
F100/350 352/360/390: The right (passenger) side exhaust manifold is the same 1965/76, could have an ID number of C5TE-9430, C8TE=9430 or D0TE-9430.
D0TZ-9430-A (replaced C5TZ-9430-A & C8TZ-9430-A) .. Right (Passenger) Side Exhaust Manifold / Obsolete
The left (drivers) side exhaust manifold is the same: 1965/67 F100/350 352 & 1973/74 F100 360. ID number C5TE-9431.
C5TZ-9431-A .. Left (Drivers) Side Exhaust Manifold / Obsolete / These trucks have a heat riser valve, the manifold is machined for it.
Excepting the heat riser, 1968/76 left manifold is the same, ID number C8TE-9431 / Ford part number: C8TZ-9431-A
I saw a new pair online for $75 + free shipping. Probably made in China, but if they work, it's a good price. I paid that for a used set.
Ford F350 Truck Ford Pickup 352 390 Exhaust Manifold Pair - AM Autoparts
Check this out
Dean M's 427 on the dyno
Remove your headers to go back to manifolds?? If Steve McQueen were here,
he would slap you.
If you want to quiet the truck down, go to a set of 60 Series FlowMasters, but don't go
and do something that's going to choke off the engine airflow. There is so much technology
in mufflers now that still allow decent performance.
If you do this you will no longer be able to refer to yourself as "BigMike". We will call you
"Francis".
Jason
he would slap you.
"Francis".
Jason
My truck had headers on it when I bought it. They fit poorly and i was replacing gaskets on a regular basis. I also didn't like removing the header to replace the starter. I replaced them with stock manifolds and haven't had a problem since. Steve McQueen might want to slap me, but it's a truck not a race car. When I want to go fast, I drive one of my Mustangs.
on
Manifolds
Truck manifolds are bigger than car manifolds. FE engines (truck) from 65 through when Ford stopped making them use the same manifolds. Likley Ford sells them. Truck manifolds flow pretty well for just driving around. Headders are great for race cars but are a real PITA when it comes to leaks and cooked starters. So if you are just driving your truck, manifolds are fine. Be sure they are flat and true (machine shop) and add a set of gaskets. Follow torque sequence and specifications. True duals with a crossover pipe or even a X pipe if you want to spend a few bucks. Not interested in re-starting the age old pi$$ing contest about headders verses manifolds. This is my opinion based on 50 years experience working on these old trucks. IMHO!
DOTZ-9430-A (replaced C5TZ-9430-A) .. Right Exhaust Manifold / Obsolete
Applications: 1965/67 F100/350 352 / 1968/76 F100/350 360/390.
HAVEN FORD in Haven KS has 1 = 620-465-2252.
COLLECTORS AUTO SUPPLY in Oroville WA has 1 = 800-414-4462.
WESLET OBSOLETE PARTS in Liberty KY has 1 = 696-787-5293.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 3 = 800-476-9653.
C5TZ-9431-A .. Left Exhaust Manifold-Use with Heat Riser Valve / Obsolete
Applications: 1965/67 F100/350 352 / 1973/74 F100 360.
KOEHN MOTORS in Wellington KS has 1 = 620-326-5915.
C8TZ-9431-B .. Left Exhaust Manifold / Obsolete
Applications: 1968/72 F100/350 360/390 / 1973/74: F100 390 & F250/350 360/390 / 1975/76 F100/350 360/390.
CROSSET FORD-LINCOLN in Crosset AR has 1 = 870-364-2162.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS has 23.
C5TZ-9A427-A .. Heat Riser Valve-1.00" thick body / Obsolete / 39 available NOS
Applications: 1965 F100/350 352 before serial number 672,001.
D3TZ-9A427-A (replaced C5TZ-9A427-D 1/1973) .. Heat Riser Valve-1.56" thick body / Obsolete / 21 available NOS
Applications: 1965 F100/350 352 from serial number 672,001 / 1966/67 F100/350 352 / 1973/74 F100 360.
taylorjgreen
09-12-2009 07:59 AM
37 Ford guy
05-09-2009 05:45 AM
