Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 11-17-2014, 06:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
Escape Alternator replace the easy way
Old 03-03-2012, 04:55 PM
yeksun's Avatar
yeksun
yeksun is offline
I just replaced an alternator in a 2003 escape It took me 2 hrs and I had never replaced one on an escape before. The manual says to remove drive axle.( yeah right ,that wasnt going to happen).Here is how I did it and how I will do it every time from now on. Sorry no pics.
The vehicle is a 2003 escape 4x4
Remove right front tire and plastic splash shield
Remove serpentine belt
Remove upper intake manifold (this sounds way worse than it is I have done this before and I am familiar with the process so it took about 15 min. it may take you a couple mins more the first time but the payoff will be worth it believe me.) Dont forget to have a new gasket set ready about $8
Remove 2 bottom alt bolts 13mm (reach through the wheel well)
Remove 1 top alt bolt 13mm (reach over the top of the engine down the back of the firewall)
Now move the alt. so that you can disconnect the electrical connector and remove the battery cable mine was a 10 mm
Remove the alternator by bringing it up along the firewall. I got mine out by turning it so the pulley was facing the drivers side of the car. slowly and carefully move the alternator up and out, moving tubing and wires out of the way as needed
Replacement is the reverse just be careful when lowering the new alt back into place not to snag any hoses or wires
This was a pretty easy way to do this in comparison with how they want you to do it. Good luck
Old 03-04-2012, 12:34 AM
rlester's Avatar
rlester
rlester is offline
This is a great tip, thanks for posting this.
I just bought a 2006 Escape for my wife with 170k kms on it. I'm pretty sure in the next couple of years I will have to change the alt on it, so this is good to know. Although, my 86 F150 still has the original alt on it with 290k on it. The originals seem to last the longest in my experience.
As stated, your method is MUCH simpler than removing the front axle.
Old 03-04-2012, 08:37 PM
yeksun's Avatar
yeksun
yeksun is offline
Your welcome.
After I saw the recommended repair procedure and then I figured out the other way I just had to share my findings with everyone. I am glad that this will be useful to you someday. Thanks for the comment
Old 03-04-2012, 11:54 PM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
Good to know did you throw new plugs,pvc valve in also since you are right there!!
Old 03-05-2012, 09:54 PM
scott91370's Avatar
scott91370
scott91370 is offline
I don't know if I would call it MUCH simpler. It's only 3 bolts (maybe 5) to remove the axle. I haven't tried it the way above and hopefully I never have to replace another one.
Old 03-09-2012, 12:43 PM
944_s_type's Avatar
944_s_type
944_s_type is offline
I have an alternator or more correctly a Voltage requlator that is not putting out over 12 V. I just picked up a new alternator, and a set of plugs, and a gasket kit.... Guess I'll have a fun weekend. Now If I could only get the damn truck to quit vibrating!
Old 04-07-2012, 09:23 PM
cstinem's Avatar
cstinem
cstinem is offline
I have a 2004 v6 3.0 and wonder if it is different than the above alternator replacement that he was talking about. How long did it take you to replace yours? How did you take out the axle?
Old 04-07-2012, 09:25 PM
cstinem's Avatar
cstinem
cstinem is offline
Do the intake have the round gaskets? So once you take it off you can get to the top side of the alternator?
Old 04-07-2012, 10:16 PM
scott91370's Avatar
scott91370
There are a couple of bolts holding it in and one on the control arm that lets the arm swing out of the way if I remember correctly.
Old 08-16-2012, 10:25 PM
Jbizzy's Avatar
Jbizzy
Jbizzy is offline
2006 escape alternator
I found some of this information helpful but for the 2.3L Escapes you do not have to remove the intake manifold but to get the alternator out you must remove the heat sheild off of the headers. Also there is a protective cover going over the alternator and the tension pully you must remove that are held on with 10mm bolts and there is also a air vent connected to the alternator that is a 2 & 1/2 in tube you must remove to get the alternator cover off connected with push in clips on both sides of the tube. When you finally get to the alternator the mounting bolts are 15mm with one retainer bolt on the cover and another behind the cover for the top bolt of the alternator other than that you do not need to remove the axle.
Old 09-05-2012, 07:27 PM
scott91370's Avatar
scott91370
Well I have to go at this again. TWO YEARS is all this one lasted - 60k miles. Last one I bought was $240 this one was $340. I'm thinking of keeping the core and rebuilding it just in case I need it- hopefully this vehicle is be gone next September- it'll be right at 290k miles at that time.
I may have to recant my statement above about it not being much simpler as I just replace the plugs and remove the mani wasn't mearly as hard as I thought it would be. And, since I have't put it all the way back together I'm already ahead a good 15 mins! I will post up and let everybody know which way I prefer.
Old 09-06-2012, 11:07 PM
scott91370's Avatar
scott91370
Well I finished the alternator and in my opinion taking it out through the top was not any easier. I'll stick with the 4-5 bolts it takes to pop the axle off instead of removing the dozen or so it takes to remove the intake mani.
The things I found that made it more difficult:
Lift it out - trying to hold it while lifting and tilting ( I ended up putting twine in one of the bolt holes to lift by)
Putting the bolts in: with the axle in the way it was difficult to hold the alternator up so the weight wasn't on the bolt when starting
It was worth a try though.
Old 09-07-2012, 05:44 PM
fmtrvt's Avatar
fmtrvt
fmtrvt is offline
Thanks for trying out the alternate method and opinion.
Old 08-30-2017, 09:15 AM
MrFixItall411's Avatar
MrFixItall411
MrFixItall411 is offline
Needing advice
ok so I just changed my alternator on 06 escape and the new one wasn't working so I did it again after it tested good but it's still not charging. I checked the fuseable link, good, the fuse, good. The old alternator tested bad but it was working before it went out. Any ideas? How do I test the three prong plug on the back of the alternator?
Old 08-30-2017, 08:08 PM
tnfordblue's Avatar
tnfordblue
tnfordblue is offline
I replaced mine as well a couple of years ago and couldn't get clearance with the axle removed. Almost cut access hole in floor/firewall, but then watched YT vid. Pulled it out the top with a string attached to it. Barely tore a small hole in firewall insulation. Gravity helped getting the new one in.
Quick Reply: Escape Alternator replace the easy way
