Just about to order a 2012 Chassie Cab 6.2
I am very close to putting the order in for a brand spankin new 2012 F350 Extended Cab XLT DRW Chassie with the 6.2, But I have a few questions?
(First new truck I ever have purchased) I have never wanted to take the hit new but when they give you what you paid for your old truck you cant say no!
Should I get the 3.37's or 4.10's?
Its going to have a dump body on it and be towing/hauling every day and plowing snow in the winter with occasional interstate travel, what do you guys think?
Im upgrading from a 08 V10 chassie with the same specs. Can I expect an increase in milage, have you guys run E85 in them with any plus sides?
Is the sync system worth it?
Anything else I should be looking out for or things I should be aware of!
I wanted to go with the 6.7 but its too expensive! I plan on turning this thing back in at 60-100K for a new one. Maybe the next will be a diesel.
I was pretty impressed with the get up and go from the 6.2
Thanks in advance! Ill throw some pics up once she get upfitted in 9 weeks
I would think that under the conditions that you outlined,...primarily a WORKING TRUCK, you should go with the 4.30 gear ratio and expect to loose 1 to 2 MPG at highway speeds over the 3.73 millage but you would probably break even if you are working the truck and using the 6 speed transmission in the lower gears if you had the 3.73 verses the higher transmission gears with the 4.30,....so your call but I would go with the 4,30 and you will probably still get better overall millage than your current V !0 and have more power.
Here's my 2 cents. I ordered the 4.30 gears for my F350 to maximize the power. It sounds like guys with the 3.73 gears are having to run in 5th gear at a higher rpm while towing. I thought with the lower gears it would be able to stay in 6th gears running at a lower rpm to increase fuel economy. I will soon find out, it sounds like I should get it in 3 weeks.
MarkNix
2017+ Super Duty
10-10-2018 04:52 AM
