Rear leaf spring shackles
Old 02-22-2012, 04:50 PM
CamaroAdam73's Avatar
CamaroAdam73
CamaroAdam73 is offline
Where can i find a set of rear leaf spring shackles for my 84 F150 2 wheel drive?
Nobody seems to carry them, i've been finding allot of aftermarket kits that don't resemble the original parts.
Old 02-22-2012, 06:39 PM
GLR's Avatar
GLR
GLR is offline
I got both the rear frame spring hanger, and the shackle from a local Ford dealer.
PS, have you checked with our sponsors and other advertisers on this site ?
Old 02-22-2012, 07:21 PM
86fordtruck's Avatar
86fordtruck
86fordtruck is offline
You could look in the bed of my truck out in my driveway. I've got a set I pulled off my 86 F150 4x2 SWB since I am changing the rear suspension to a 4-link. They sit there, with the leaf springs, front and rear brackets, and even the upper shock mounts. How about the bolts? You good there?
Ron
Old 02-22-2012, 07:25 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,680 Likes on 1,357 Posts
My Ford dealer had the frame bracket in stock, and I only paid $40 for it. I bet they have the shackle too.
Old 02-22-2012, 11:24 PM
Redneck1465's Avatar
Redneck1465
Redneck1465 is offline
Ford and autozone have them. I bought the driver side from ford and passenger side from autozone.
Old 02-23-2012, 07:12 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by CamaroAdam73
Where can i find a set of rear leaf spring shackles for my 1984 F150 2 wheel drive?
Note: These are the shackle kits, not the spring hanger brackets that are riveted to the frame rails, and are prone to rusting out.
EOTZ-5630-G .. Right/Left Rear Spring-FRONT Shackle Kit / Obsolete
Applications: 1980/96 F100/150 2WD.
KOENECKE FORD in Reedsburg WI has 1 = 608-524-4361.
STAR FORD-LINCOLN in Streator IL has 2 = 815-672-3187.
BOYD COUNTY FORD in Ashland KY has 3 = 606-329-2120.
GREEN SALES CO. in Cincinnati OH has 14 = 800-543-4959.
E2TZ-5630-A .. Right/Left Rear Spring-REAR Shackle Kit / Obsolete
Applications: 1982/85 F100/150 2WD.
JST AUTOMOTIVE in Lebanon TN has 1 = 615-443-3086.
Old 02-23-2012, 07:20 AM
CamaroAdam73
Crud, i work part time at auto zone and we can't get those parts anymore. The local ford dealership is called suppes, and they said they can't either.
Old 02-23-2012, 07:25 AM
NumberDummy
I found 20 NOS front kits and 1 NOS rear kit...see above. NOTE: The bushings can be bought by themselves, so there's no need to buy kits if all you need are the bushings.
Old 02-23-2012, 07:54 AM
86fordtruck
I pulled the springs, shackles, and mounts off my truck a few months ago. I put my eyes on them last night. They are solid, and only need to be cleaned up and hit with a coat of paint to look like new. The shackles are worth about 25 cents each as scrap metal which is where they are heading. Now, if I only knew someone who could use them....
Old 02-23-2012, 10:42 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
FORD, NAPA, ADvance, Autozone, Stengle Brothers all HAVE them.
Who ever is telling you otherwise is full of *****
Old 02-23-2012, 12:42 PM
NumberDummy
Originally Posted by Diesel_Brad
FORD NAPA, ADvance, Autozone, Stengle Brothers all HAVE them.
I'm not FOS, and I do not appreciate being called a liar! See post #6 for the Ford part numbers and the APPLICATIONS.
F250 is not the same. The OP's truck is a 1984 F150 2WD. 1980/81 F100/150 2WD, 1986 and later F150 2WD do not use the same rear spring-REAR shackle kits as 1982/85 F100/150 2WD.
The Ford Dealer Parts Locator System has no PDC (Parts Depot Center) status for either kit, which means they are cancelled, obsolete, not serviced, not replaced = no longer available from FoMoCo.
Type both part numbers in tousleyfordparts.com and/or partsguyed.com websites and this is what you'll see:
EOTZ-5630-G = Part Discontinued.
E2TZ-5630-A = Part number not found. The kit is obsolete, that's why the number is not found.
If you think my part numbers are wrong, get yourself a 1980/89 Ford Light Truck Parts Catalog and look the part numbers up yourself.
Ridiculous! I've looked up and found 1000's of Ford parts for FTE members, available and obsolete. This is the first time I'm being called a liar for doing so.
Old 02-23-2012, 03:19 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Assuming there is no confusion as to the parts being talked about here....
Yes, I agree, put the part numbers into those Web sites Bill listed above and see what comes back from Ford. Even though both sites will allow you to Add to Cart, pay attention to where they say the parts are discontinued because, even if you give them money and try to buy the things, they'll send you an e-mail saying the part is no longer available. I made this mistake long ago, before FTE and before I understood what was happening.
Then, put 'em into partsvoice.com to see what NOS retailers say they have to sell.
There may be others around at various Ford dealers that don't participate in the Dealer Locator System or the PV system (or don't have old parts like this listed in them) but consider yourself lucky if you find such a dealer.
PV has been known to be wrong, too - it can sometimes take a lot of time before it's updated with current information as vendors sell things.
Bill - looking at Brad's post, my general sense is that he's referring to parts counter guys at local dealers the OP is going to, not you in particular.
Brad - am I wrong? If not, please tell us what Ford dealers have these things.
Old 02-23-2012, 03:28 PM
Archion's Avatar
Archion
Archion is offline
Are they 3"? Do they look like these?
Old 02-23-2012, 05:23 PM
fellro86's Avatar
fellro86
fellro86 is offline
Autozone has them listed for 250, 350. Look them up as a 150, no listing. Rock Auto specifies the same one AZ had for 250's, but qualifies them as 4wd...
AZ and RA agree on Dorman 722-004, but with the mentioned qualifiers.
Old 02-23-2012, 06:30 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
I just bought these for my 95 f 150. When the box got here, to my surprise, everything had ford part number stamps on them. I guess someone bought out a parts department somewhere
Rear leaf spring hanger kit F150 4wd F250 2wd or 4wd | eBay
Quick Reply: Rear leaf spring shackles
