1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
GEM module
Old 12-28-2011, 04:06 PM
96max2fast's Avatar
96max2fast
96max2fast is offline
Originally Posted by Moto Mel
If the GEM got wet after it was dry and the windshield was resealed the reseal was not done properly. I think the only other possibility would be a sun roof drain leaking inside.
the windshield was removed, the old gunk was scraped off and and it was resealed and the moldings were all sealed... i dont have a sunroof...
any other suggestions? how about those duct vents by the wipers? any way water can get into one of those places?
  #32
Old 02-27-2014, 12:51 PM
gmm321's Avatar
gmm321
gmm321 is offline
GEM/FUSE BLOCK PROBLEMS
Hi BLOW, am new here, but recently went on trip to Oregon from Washington in a torrential downpour. Got to Salem, OR and everything went nuts, dash lights, warning icons, wipers, blower, etc. When I turned the key off, everything was still "hot". Fiddled with the key a few times and the stuff quit doing it, but could still hear relay chattering under dash. Took to Ford. Yep, LEAKING WINDSHIELD, right down the A post and right into the fuse block/gem. This is a 98 Expy. Ford says "yep, a well known problem with the 97 - 02 Ford Expy's and F-150 but they wont do anything about it". I got the thing home, put a hair dryer to the fuse block/gem module and as things dried out everything started working again. You CAN NOT reseal a windshield unless you want to just make a ugly looking one. I am having my windshield replaced by Safelite tomorrow, then I will tackle the fuse block/gem problems. Can't really work on them till it warms up here, we are in middle of winter and I don't have a garage.!!
  #33
Old 03-01-2014, 03:26 PM
Icefan71's Avatar
Icefan71
Icefan71 is offline
I just had my windshield replace by Safelite at their shop. I asked the installer if there were any signs of water leaks. He said the problem wasn't the windshield in these trucks. Its the seam sealer running along the sides of the roof. He said they dry up and crack, allowing water to get behind the windshield and down the A pillar.
  #34
Old 03-20-2018, 10:39 AM
wsdavis53's Avatar
wsdavis53
wsdavis53 is offline
GEM Probs and Leaking Windshield/"A" Pillar
I know this is an older Thread, but I have a question for Icefan71 regarding his trip to the Safelite shop. The Safelite tech said it was dry/cracked seam sealer along the sides of the roof. Did he offer any fix for that? Thanks. I've got similar, bizarre behavior with my 2000 EB EXPY and I suspect its my GEM.
  #35
Old 03-21-2018, 10:05 AM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
Might be better if you shot him off a PM, at least he'll get an email telling him he has a message.
  #36
Old 11-03-2022, 08:19 PM
Wiserandy72's Avatar
Wiserandy72
Wiserandy72 is offline
1st Gear
Gem modul
Originally Posted by stardust
I had this same problem, but my wipers wouldn't work at times while it was raining. I did some research & found that a lot of expedition owners have this problem.
Me as well had the same problem with my 99 f150. Wipers dont work at all and stuck in the up right position on my windshield. Thought it was the switch on the steering column but changed it and didnt fix the problem.
Wrecking ball
07-24-2021 02:08 PM
CLE-PRE
02-09-2017 02:30 AM
plgebbia
07-26-2011 06:00 PM
jlcparis
04-23-2010 02:48 PM
ksw390
1999 to 2016 Super Duty
03-29-2010 10:14 AM
Quick Reply: GEM module
