Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
fuel gauge not working on 02 explorer
Old 02-22-2012, 11:27 AM
plumbkrazy428's Avatar
plumbkrazy428
plumbkrazy428 is offline
I have a 02 explorer an the fuel gauge works when it wants to, it will come on for a few min an then go to empty I have replaced to gauge cluster, what else can I do before droping the tank
Thanks
Old 02-27-2012, 08:51 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
the gague is just a volt meter and is reading a voltage across a variable resistor inside the tank. Resistance changes as the level goes up and down. If the gauge stops working, (only part of the time) normally you have a bad wire or connection. Look by or near the tank, that is the normal spot. Could also be the plug at the tank float. Normally if the float resistor is the problem, you will read when the tank is full or empty but not both. If your reading is random and not related to a specific level-- you have a wire connection problem.
fordexplorer10
07-18-2018 01:10 PM
Loganc95
04-15-2013 01:37 PM
WiNgRg
04-06-2010 01:08 AM
gavin_smith_1999
03-30-2003 05:58 AM
soso
12-08-2002 12:09 AM
Quick Reply: fuel gauge not working on 02 explorer
