Does any one know the torque spec on the brake caliper bolts. I need the spec on the two motnt bolts on each side of the rear and the four mount bolts on each side of the front. It is on 06 f150 4x4 5.4l.
Thanks
Jeff
Thanks
Jeff
I will dig around and see if I can find it for you.
