1996 F250 HD: Turns over, but won't start, argh!
This is a '97 HD F250. It has the 5.8L 351 Windsor. Anyway, it sounds like it wants to start, the engine cranks, but it sounds like it is not getting gas. I have changed the fuel filter, and we can hear the fuel pump engage.... What else should I check? I am a NOVICE, so please speak plainly! I appreciate any and all help. Mike.
Is it cranking over solid, or does it seem to be kind of sluggish and slow?
Have you checked for spark? When is the last time you checked/replaced your air filter? It may be useful to remove the air filter and then try to start it, just to see if it is an air flow problem.
The easiest way to check and see if it's getting fuel is to remove the cap on the shrader valve. I don't have a pic of it, but it will look like a tire stem on the fuel rail. Engage the ignition so the fuel pump primes [or at least SHOULD prime the rail] then remove the cap from the valve and use a small screwdriver to depress the valve stem. BE CAREFUL- if there is fuel present it will shoot out very fast.
But, if you have a fuel pressure tester, it's always best to use that instead.
You may also want to check the fuel pressure regulator. This is a small cylinder that will be located at one end or the other on the fuel rail as well. There will be a vacuum line hooked up to it. Remove the vacuum line and look for gas dripping out of it, or if you can smell gas when the line is removed, it's bad.
Okay, the pump engages for at least a full second, then it stops and a half second later the engine tries to start. Now, a couple of times it seems like the pump stayed on, because there was no silence between it turning on and the engine turning over. (The noise of the engine turning over makes it hard to tell if it is still on or not.)
Sound like a bad pump?
Does it have 2 tanks?? If so try starting on the other tank, that should rule out if it is a bad pump..
Just turn the key to the on position and listen for the pump to run for a second or so then cut off.. You don't have to be cranking for the pump to work...
You could even turn the key on several times before cranking to give a weak pump time to catch up....
Okay, replaced the Fuel Pressure Regulator and the Fuel Filter again, too, in case it dredged up something from the bottom of tank. No change. Checked the schrader valve... it sends fuel out, but only a couple of inches high. Is that normal? Or should it shoot up and hit the hood!?!
Is it possible, that even with new plugs and wires, that it's not getting any spark? Distributor cap? Tune up parts? I am a rookie, so does any of this make sense?
What doesn't make sense to me is, after it didn't start for about 8 or 9 months, we changed the fuel filter, and it started up and ran like a champ for about 2 or 3 weeks.... then back to not starting.
Any and all ideas welcome.
Thanks again for all your help. Mike.
Can't say for sure; a neighbor mechanic picked it up and put it on for me.... the Kit came with the Pick Up Coil though; He didn't replace the Dist Cap and it didn't want to start..... New Cap, and it was running again. I think the whole kit was like $40 at AZ plus about $10 for the new Cap. Sorry I can't be more detailed about which one, but hope this helps. Mike.
