Overhead console removal?
LOL! I'll just pull on it with a little more enthusiasm and if that doesn't work, I'll get the wife to lend a hand.
Thanks for the tip.
upper console
Once you have removed the upper console, can you replace the LED's that show compass, gas mileage etc?
There is another thread about this very topic that was started today (console removal).
It is a common problem for the circuts to come loose (soldered connections come loose internally over time).
The other thread had a nice write-up with links to pictures.
As well, there was a link to a company that you can send the unit to and they will repair and test it for you for around $35.00 (seems well worth it to me).
Good luck,
Good luck,
https://www.ford-trucks.com/forums/s...d.php?t=441601. $16.00 at radioshack for a low watt soldering pen and a steady hand is all it takes. read post with red links and your good. by the way was my first attempt at soldering anything, just make sure to not cross any circuits with. the solder.
David can repair your Overhead Console for $22.00 with lifetime warranty.
http://item.mobileweb.ebay.com/viewi...id=19289165983
David Ruberg 507-429-4489
Never have to worry about it again OR spend anymore $$. Just a thought!
FORD F-series Overhead console kits and Parts
Ford F150 F250 F350 Super Duty Temperature Compass Overhead Console Disp Repair | eBay
