PCM pinout
https://www.ford-trucks.com/forums/1...27-pinout.html
Here is the PCM pin-out.
Use THIS LINK to go to my last post in your other thread for an Engine Control Schematic I attached there.
Edit : No more back and forth. Here is the Engine Controls Schematic
42 Pin Connector. GPR control leads pass through it on there way to the PCM. See my post in your other thread.
Sorry about making you dizzy really not my intention. The wire schematic and pinout are wonderful thank you. So today I have checked the glow plug controler output or pin 101 on the pcm pinout. The wire checked out ok both by ohms and by no negative or positive power. But when computer is hooked up and the wire hooked up to GPR I run a start cycle on the motor so it activates the glow plugs then the wire will have 6 to 7 volts showing. Is this normal (not acording to my research)?
Swap is in 2000 Excursion with 6.8 engine. Old engine had 325 K miles on it and found 2017 6.8 with 6 R 140 with 40K Ks. Got complete harness from F450 but dash harness not same. Need the pin layout to do the proper swap and just plug and play. Do not want to cut and solder wires.
Thanks.
Thanks.
@Hondo2K12 , I am not 100% sure what it is you are asking for, but we can most likely help with the 2000 Excursion 6.8L pinouts. Although, if you want to have access to the diagrams, pinouts and connector details for them yourself, please see the link below.
Ford Service Manual?
awillo0406
16
04-08-2013 09:16 PM
