Speakers 2007 expedition limited
I think once the speaker has gone its a good time to upgrade, I'm not 100% sure but i want to say these are probably 2ohm speakers, which i would recommend getting new ones. if you dont want to change the amp i would go with 2 ohms as well, if you dont mind spending some cash its a great time to upgrade.
Just for reference, here are the factory part #'s for the Audiophile setup.
Front Door Speakers -# 8L1Z-18808-B
Rear Door Speakers - # 7L1Z-18808-C
Tweeters (*order by color and side) - # 7L1Z-18808-AA*
Subwooofer (I believe this is the Woofer and Enclosure) -# 7L1Z-18C804-AA
Also, the speakers are 4ohm except the subwoofer which is 1.5ohm DVC.
The front speakers have built in crossovers that attach to the tweeter also.
Matt
Matt
Did you replace the amplifier? or are you running the stock one? if so which one do u have?
No. I use the stock amp. I chose Infinity becuase they are the most efficient speakers out there. It gets plenty loud with the stock amp. That is not to say you couldn't replace the amp, just that I don't need too.
Joe
10-05-2004 10:50 PM
