Spicer front U-Joint prices
Old 02-07-2012, 12:58 PM
ATG_Tuning's Avatar
ATG_Tuning
ATG_Tuning is offline
I am compiling a list of where to get the best parts for our trucks at the cheapest prices. I am a firm believer that if you are going to replace something than you use factory or better parts.... so don't expect a list of Chinese knock-offs...that is not what this is. If you like to replace things over and over again than do not read this.
If you want to put parts on your truck that will last and serve you well, then read below.
Old 02-10-2012, 07:26 AM
ATG_Tuning's Avatar
ATG_Tuning
This thread started with me simply trying to find the Spicer u-joints at a reasonable price (hence the title). It has since changed to a more comprehensive/growing list of parts we should all have on our trucks. Please add your secrets if you have any... with how things are right now, Lord knows we could all go to save a buck or two.
Below is a list of parts that I have ordered and where I found them at the best price:
Spicer front u-joints - $107.38 w/shipping and tax from drivetrain america (not bad considering most want 65+ for just one)
Moog upper ball joints - $25.16ea w/ free shipping from amazon
Moog lower ball joints - $42.96ea w/free shipping from amazon
Yellow hub o-ring - $4.11ea from Ford (part #F81Z 4A322AA)
Large outer axle seal - $34.06ea w/ free shipping from amazon
Small inner dust seal - $15.51ea w/ free shipping from amazon
Axle needle bearing - $11.98ea w/ free shipping from amazon
Hub o-ring kit (if needed) - $7.90ea w free shipping from amazon
Timken hub/bearing assemblies - $169.99ea w/free shipping from amazon
Taller back lift supports that should have been factory on our trucks (best mod i have done!) - $22.05ea
Front sway bar links - $49.89 and $50.79 for right and left (respectively) from old reliable...RockAuto
A lot of stuff was cheaper at Amazon.com than it was from RockAuto!
Hope this price list helps someone... I will continue posting good prices for items I buy, please do the same, always nice to save a couple dollars. If you have found any of the above items for less, please let me know and i will update the list.
Old 02-27-2012, 09:08 PM
ATG_Tuning's Avatar
ATG_Tuning
more added
Plan to pick up some energy suspension front poly sway bar bushings soon also... will post where the cheapest i find them is when i get them.
Old 04-22-2012, 05:37 AM
fonefiddy's Avatar
fonefiddy
fonefiddy is offline
Hard to belive that You'd buy the more expensive spicer u-joints and then buy cheap Moog Ball Joints. Should have gotten the Spicer B-joints.
jarhead2147
07-06-2017 12:44 PM
four-sixty-power
03-03-2017 10:10 AM
wmjoe1953
06-29-2011 04:56 PM
damac
11-11-2010 07:38 PM
stegmst
04-17-2005 10:53 PM
Quick Reply: Spicer front U-Joint prices
