Will this PTO bolt to my Transmission?
Old 02-06-2012, 01:55 AM
packratF350's Avatar
packratF350
packratF350 is offline
First off, I'd like to thank the guys that posted pics of their engine compartments for me a while ago...they were invaluable in getting my truck up and running again!
One of the trucks I am parting out has a PTO driven winch on it. I'm considering installing it on my flatbed instead of an electric unit (this will be used to operate a tow sling, GIN poles and loading the deck with whatever).
Donor truck:
early to mid 70's Ford 4 speed (reverse is right and back = NP435??)
PTO is mounted to the passenger side of the transmission.
My truck:
'94 F-350 with a ZF5 5 speed. I'm not even sure at this moment if it has a PTO opening, been too busy with getting it running to date and this idea just popped into my head tonight.
any thoughts or advise?
Old 02-06-2012, 06:31 AM
frederic's Avatar
frederic
frederic is offline
I don't think the older stuff mounts on it though, but I'm not sure. I can answer the other question though - your ZF has two PTO take-off ports. You have a PTO cover on each side - for two accessories.
Old 02-06-2012, 09:09 AM
packratF350
I've been doing some other research into this, and I found a rebuild shop that says basically, due to the design of this transmission, its not a very good idea to run a PTO for any length of time with it (and specifically mentions tow trucks and winches) due to internal heat build-up. Any thoughts here?
Old 02-06-2012, 09:20 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
That is a load of crap. If it was so bad for the trans, then why did Ford have the provisions put into it for a PTO
Old 02-06-2012, 09:25 AM
GNR22's Avatar
GNR22
GNR22 is online now
Fabri-cobbler
I agree with Brad. There wouldn't be one if it couldn't take it. The ZF trannys are tough as it is, and it shouldn't have any adverse effects on anything else. I'd say go for it.
Old 02-06-2012, 11:08 AM
packratF350
quote from the rebuild place...http://www.standardtransmission.com/ford_zf.html
In late 1987, Ford introduced the 5speed ZF transmission in the F250, F350, & F450 trucks. They were available for gas as well as diesel models. The easiest way to identify the unit is to see that it has power take off (pto) opening plates on the lower sides of the unit. ZF transmissions are reliable units that should provide good service when taken care of properly. Keep in mind that the ZF has 6 constant mesh mainshaft gears, so there is a considerable amount of potential for heat buildup. It is never a good idea to leave the truck idling with a pto engaged, such as in tow truck applications. The unit was redesigned in '96 and had small, but significant changes. The synchro teeth were enlarged to provide longer life and more positive shifts, and the bearing retainer was designed to be replaced without having to disassemble the case. The case was beefed up also with this design.
Old 02-06-2012, 12:33 PM
Diesel_Brad
Originally Posted by packratF350
quote from the rebuild place...Ford ZF Transmissions
That means dont leave the PTO in for hours on end. Neither a tow truck or winch will be used for more than 30min at a clip
Old 02-06-2012, 12:57 PM
packratF350
Ok then that question is taken care of.
Back to the original question, anyone think the PTO off hte older transmission will bolt onto the ZF and work properly? Or am I wasting my time and should just go with my original plan and use an electric winch?
Old 02-06-2012, 01:06 PM
Diesel_Brad
The ZF uses a 6 bolt PTO. I cant remember what the NP435 or T18 uses
Old 02-06-2012, 01:11 PM
bashby's Avatar
bashby
bashby is offline
I think I heard somewhere in my travels that there are 2 different ones out there, one coarse toothed gear and one fine. You might just need to try it if nobody can tell you for sure. Is there a tag on the unit you want to install with make/ model? I'd try googling that and see what you can come up with.
Old 02-06-2012, 03:47 PM
packratF350
I dont know yet...I need to dig it out of the pasture/bushes as I get caught up on other projects so we can tear into it.. I will be pulling the engine/trans, PTO powered deck winch and the gin poles off it as well.
I'll keep you all updated as to weather it will work or not when I get that far!
Old 02-06-2012, 03:57 PM
hootvan's Avatar
hootvan
hootvan is offline
You need to get the model off of the PTO and the actual transmission model number and I could tell you if it would fit. It may be as simple as changing the input gear on the PTO to make it fit the new transmission. There should be no problem with overheating as you won't run continously.
Old 02-07-2012, 08:18 AM
packratF350
I'll hit you up as soon as I get into working on it! Thanks!
ChristiansenP
07-07-2016 09:49 PM
wr310rdr
06-08-2013 03:07 AM
thekingofcows
28
12-22-2012 11:43 AM
mike potts
08-18-2009 10:45 PM
phatpharm85
02-29-2008 10:25 AM
Quick Reply: Will this PTO bolt to my Transmission?
