My 2000 v10 w/194K has developed an intermittent shake when braking. Severity from mild to severe. Had the problem earlier, suspected the rotors - replaced front rotors and pads with EB slotted rotors and Yellow Stuff pads. It was fine for a couple of months, now its back. Replaced the slide pins last night (they were in good shape, replaced anyway). Any ideas on where to look next?
Mine does this too.. I haven't changed anything yet, but its very intermittent... seems like its worst when I haven't used brakes for a while, like on cruise control on the interstate and I tap the brakes when someone pulls in front of me going down a hill.
Edit: all of my superduty's have done this at one time or another. Under heavy braking it is much worse, but light braking it is just a vibrating annoyance.
Everything is tight in the front end, however I don't like the sound of the right front wheel bearing. Has anyone ever had a bad bearing cause this type of problem- seems possible. I will tear down and report back.
Check your Connecting Drag Link at pitman arm. Mine is worn and causes a sort of "juggling" in the steering wheel when driving. Sometimes it's more noticeable than other times.
