First potential issue from the 4wd conversion. The ABS light stays on constantly. The computer says no signal from either front hub. I suppose we could have 2 bad front hubs, but that seems unlikely. Another possibility is some different signal from the '06 4wd system and the '03 2wd system. Anybody got any thoughts? Thanks.
I don't really know, all I did was look up part numbers.
Roger that. I'm thinking this may be an undefeatable wiring harness/computer issue. If we had '03 4wd speed sensors rather than '06 ones, I wonder if my '03 2wd computer would tolerate that or still see it as a problem?
Not sure, I did PM someone that may be able to help though.
Anybody know if the light being on necessarily indicates that the ABS will not work properly? Though I haven't breaked hard yet, the brakes seem to work fine.
IIRC when the ABS light is on the system is completely disabled. You will have regular braking capability, but there will be no antilock function.
