Testing Smart Junction Box - 2005 Escape Limited
Hello,
I had to take my 2005 Escape Limited (3.0L, FWD) into the shop this weekend, because I was having issues with my rear wiper working intermittently. They said that I have a bad rear wiper relay, but recommended replacing the entire smart junction box. My extended warranty would not cover this (of course).
How can I check to see if I actually need to replace this entire box or if it just needs a new relay. I know the smart junction box has the relay built in, but I assume I can just replace that relay? I just want to make sure they weren't trying to pull one over on me.
I plan to replace this myself (if possible). Any links on how to reprogram/replace it would be great.
Thanks for any help.
Thanks for the heads up. The weird thing is that mine will work if I turn on the rear window defroster. After about 5-10 seconds of that running, the wiper will start working. If you turn the defroster off the wiper stops working 5-10 seconds later.
So, If I am understanding you correctly. You are saying this is not a part that I would be able to replace (smart junction box), because I would not be able to reprogram it.
sk8tr ... you can physically replace the SJB, but will have a hard time duplicating exactly the programming inside which is dependent upon the original equipment installed. The SJB does things such as auto door locks, auto power window down, interior lights, and accessory power for radio & windows after the key is turned to off.
If you can find a used one from a recycler, and match what you have equipment-wise, you may not need to have any programming done.
I thought the relays, some anyways, were plugged into the SJB, but would not bet my paycheck.
tom
tom
tom
tom
Bill, I don't think I mentioned the turn signal blinker/relay, so am lost as to the reference. What I was trying to say was that some relays are plugged into the SJB, as in removable and replaceable individually, or are stand off and wired into the SJB from diagrams I have seen.
From an economic point, it would make no sense to have the relays embedded in the SJB as the equipment level would vary across the product mix, and you'd waste a lot of relays that would not be connected to anything.
I think examining at the SJB for evidence of water damage would be a good idea. If the rear wiper has 'lost its power' but can get power from the rear defroster, I'd say wires are crossed or corroded... Something is energizing the wiper, but not its original source.
The power distribution PDF files I looked at don't show a logical way the defroster power can enable the wiper. Missing grounds can power stuff from the 'wrong end' of a circuit sometimes...
tom
tom
vdrowley
05-27-2013 10:34 PM
Sycostang67
12-22-2009 12:33 PM
