Valley pan Turbo grommet
My TURBO gasket set has a standard (CDR) valley pan grommet which is way too large for the turbo version.
First off: does this area of the valley pan see any/much pressure? I believe the extension off of the turbo housing/mount is just a drain-back, isn't it?
I'm trying to find the old valley pan I took off which has the correct grommet but so far: no luck.
Are the valley pans different or is it just the grommet?
THANKS GUYS!
THANKS GUYS!
So is it normal for oil to be forced back out of the grommet? I in the process of doing a head of job on mine. I've removed the turbo (leaving the open grommet) now I'm getting oil filling the pan when the truck is running. So there should be a liquid tight seal there?
MtTheJeffro
11-19-2015 09:36 PM
