Bolt size on f250 tailgate?
Old 01-29-2012, 06:34 PM
Gf2501's Avatar
Gf2501
Gf2501 is offline
Can someone tell me what size are the bolts on an F250 1971 tailgate? Mine never had one and I am planning to buy one with the hinges at the junk yard... So I want to make sure I take the right size socket.
Is removing the tailgate as easy as removing the 8 bolts on the hinges? The two lower bolts on each side seem a bit inaccessible with the tailgate in the way. I dont think the socket would fit there, I may need a wrench, right?
Thanks guys, I did a quick search but did not find the size on the bolts
Old 01-29-2012, 07:40 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
There should only be two bolts on each side to get the tailgate off. Can't say for sure, but either 1/2 or 9/16" socket will get them(I'm thinking more like the 9/16"). Take the bottom one off with gate up, upper bolt with gate in down position.
If that one has 8 bolts, did Ford change something after 1970? My '67, 69 and 70 were all two bolt.
Old 01-30-2012, 12:42 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Nope.
2) C4TZ-9943400-A .. Styleside Tailgate Hinge / Right/Left is the same.
4) 372421-S39 .. Bolt & Washer-Tailgate Hinge to Body / Hex head 3/8" -24 x 1" (3/8" is the thread size, not the wrench size) / Takes 2 per side.
Applications: 1964/66 F100/250 2WD / 1966 F100 4WD / 1967/72 F100/350 /// Note: 1964/65 F100/250 4WD; 1964/66 F350; 1966 F250 4WD used 1957/60 Styleside Beds.
September 1966: Ford replaced the '64/66 F100/250 2WD, 1966 F100 4WD Styleside tailgate (C4TZ-9940700-A) with the 1967 (1967/72) Styleside tailgate (C7TZ-9940700-A) for use as a service part replacement.
All the mounting hardware is the same. The tailgates look the same at a glance, but '67/72's have smaller FORD block letters which are surrounded by a raised ovate scallop line.
1973/79: The Styleside tailgate, hinges and bolts are not the same as above, but the hinges still use two bolts per side.
Old 01-30-2012, 08:20 PM
Freightrain
I didn't think so Bill. I just wonder where he saw 8 bolts at?
Kinda figured they were 3/8" thread which makes them 9/16" wrench.
blue351
11-27-2018 05:20 AM
yargnitram
07-28-2018 10:07 AM
Rabb Duke
02-26-2017 09:40 PM
nolan62
01-25-2011 02:40 PM
Tazmanian_Bronco
1978 - 1996 Big Bronco
06-01-2003 11:48 PM
Quick Reply: Bolt size on f250 tailgate?
