1986 F150 300 Wire Diagram
Old 01-29-2012, 12:57 PM
horserder007's Avatar
horserder007
horserder007 is offline
I recently bought a 86 F150 4x4 pickup with an in-line 6. I have torn the engine completely apart and I am now to the step of putting all of the wires back to where they need to go. The only problem is that the old owner has cut many of the wires and so I have lots of cut wires and no idea where they go. If someone has a wiring diagram that would be great!
Old 01-29-2012, 01:17 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,683 Likes on 1,359 Posts
Look on ebay for the correct factory diagram, or Service Manuals, Owner Manuals, Wiring Diagrams, Service Bulletins - Helm Incorporated sells the new diagrams if they have yours in stock. Autozone has free diagrams, but they just hit the high spots sometimes and are not complete.
I guess you know you have the famous computer controlled carb and distributor system, which is commonly swapped out to a older non-computer controlled dist and carb. If you do not hook everything back up correctly, the computer will not run the engine correctly unless you do the swap.
Old 02-20-2013, 12:44 PM
f100beatertruck's Avatar
f100beatertruck
f100beatertruck is offline
FYI, Helm has been back ordered for some time now with no estimate of when they might have more in stock...
I did find this for anyone looking, I know it's an old post.
1986 Ford Truck Electrical Wiring Diagrams Schematics Shop Service Repair | eBay
Charlie6244
02-24-2017 04:32 PM
ulstermotors
07-19-2014 08:34 AM
EViS
2004 - 2008 F150
07-03-2014 02:49 AM
lift_it_higher
Electrical Systems/Wiring
06-22-2008 08:44 AM
Sanddoc
08-20-2004 10:45 AM
Quick Reply: 1986 F150 300 Wire Diagram
