1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
How do I replace fuel filter on my 2000?
Old 04-21-2003, 01:45 PM
dambach's Avatar
dambach
dambach is offline
Can someone please tell me exactly how to replace the fuel filter on my 2000 Expedition - is this a difficult thing? and do I need any special tools or know-how?
Thanks
Old 04-21-2003, 03:33 PM
buzzard's Avatar
buzzard
buzzard is offline
Very easy to do and yes, you need a special tool to undo the coupler that holds the filter in the fuel line. This tool is available for sale (~$5.00) at any auto parts store and is probably available as a loaner from most. Ask a store employee.
It is recommended that you release the pressure in the line before starting the project. I didn't on mine and only got a trickle of gas when disconnecting the line. Whatever you do, be careful around raw gas.
The filter is located directly under the drivers seat on the frame. You'll insert the tool onto the line and separate the fuel filter from the line on both sides of the filter. Then twist the filter out of its bracket. Insert the new filter in place and snap the fuel lines back on. Make sure you have the directional arrow pointing the correct way.
Good Luck.
Old 04-21-2003, 05:46 PM
dambach's Avatar
dambach
dambach is offline
Thanks, Jim!
KD
Old 05-20-2003, 03:47 PM
KHaga's Avatar
KHaga
KHaga is offline
I've been wanting to change my fuel filter soon...but was concerned about how much pressure there was in the line...so how do you relieve the pressure in the fuel line before changing the filter? My 2000 EB has almost 60K on it...I would prefer to change the filter myself.
Thanks
Old 05-22-2003, 02:36 PM
FordPower2000's Avatar
FordPower2000
FordPower2000 is offline
Question How do I replace fuel filter on my 2000?
Is the fuel filter inside the truck our outside. When you say it is under the seat do you mean right under it on the inside of the car?
Is it necessary to buy that tool or can we do without?
Old 06-08-2015, 04:27 PM
jmp5b1's Avatar
jmp5b1
jmp5b1 is offline
It's on the outside, under the vehicle, located about where the driver's side seat is on the inside. Also, I don't think anyone can replace that filter without the specialty tool.
Old 06-09-2015, 12:10 PM
alloro's Avatar
alloro
alloro is offline
Received 4,217 Likes on 2,447 Posts
He asked that question over 12 years ago, I'm sure he's changed the filter by now.
ArmyLifer
04-11-2017 01:20 PM
bart f-350
11-24-2016 04:44 PM
josiewales
07-02-2016 10:54 PM
Dustball8504
09-02-2015 05:58 AM
93 mix 'n match
1997 - 2003 F150
04-19-2011 10:47 PM
Quick Reply: How do I replace fuel filter on my 2000?
