Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- Why Does My 4WD Make Noise?
Guide to diagnose trouble and recommended solutions
F150 5.4L strange rattling noise, PLEASE HELP, I need a idea!!
I got a F150 with a 5.4L and when I'm cruising down the highway every is goin well until I start to pull a hill. A loud fast rattle starts coming from the engine compartment, it sounds like it is mainly coming from the drivers side. The noise is really evident just before the truck down shifts out of OD, then its not as noisy and goes away when the truck is at full speed and not pulling a hill. The truck has lots of power and there are no check engine or fault lights on at all. The truck never hesitates. Interesting note, it doesn't make the rattle when revving the truck up in neutral. I really have no idea on this one and it is really starting to annoy the heck out of me when driving. Any ideas would be helpful me dearly. Thanks guys!
you might look at the pcv valve i hurd a crazy sound coming from my engine and i started moving stuff and found that one of the pcv valves were either stuck or loose, either way it was bad i found an old one i had laying around, threw it in and havnt hurd it sense. the sound got louder as the engine reved up so hopefully this helps, the valves are located on both valve covers towards the back.
2007 f150 4x4 5.4L rattling under hood
I experience similar rattling. Thought at 1st was piece of loose sheet metal vibrating. No grinding. Doesn't sound like detonation/ octane rattle, had tried higher octane gas, that didn't seem to make a difference. Crawled underneath last night cant see anything loose. Was looking for broken spotwelds on exhaust heat shields. Noise is definitely from cab forward. Noise appears at approx 40mph with slight throttle pressure where load increases up to point of downshifting transmission. Normal driving- no noise, no vibration. Cruising 55+- no noise. When it make the noise, you can depress brakes and it makes no difference. Vibration frequency not proportional to RPM. Any clues?
